Quality
Goes to exhaust and is getting dripped on apparently...
![]() ![]() and his chewed up friend? =( ![]() Thanks!
85.5 944 NA 5spd - Sold but not forgotten 89 951 Turbo S - Revival in progress...
Exhaust test point...
www.rennwish.org '88 944 NA - Red/Black with more tinkering done than probably needed. |
Quality
l0l. One down. If you're being serious that makes perfect sense. #2?
Yes!
![]() Timing mark sender... *I think*
Other two that it is attached to are the speed and ref sensors...
The "drippings" on the exhaust test port bracket is most likely oil leaking from the rear cam tower gasket. My test port bracket looked exactly like that and a $1.00 cork gasket fixed the problem. I am not positive but I thought #2 (chewed up friend) was the interconnect between the O2 sensor and the main wiring harness.
A.J.
89 944 Turbo Guru Chip Lindsey Boost Enhancer 3bar Reg. |
Back from Beyond
Yes, 'chewed up friend' is wiring for O2 sensor.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
Quality
Thank you guys.
Fortunately (can't tell in pic), it's JUST the insulation. I'll put some heatshrink on it and make it look better. =)
Trying to work for parts!
1st one is the exhaust test pipe. Not used for anything but the factory.
2nd is the O2 sensor
86 Metallic Grey 85.5 Metallic graphite - Gone |
