-   -   Turn signal (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/415057-turn-signal.html)
lyons8821 06-16-2008 04:46 PM
Turn signal
Guys my turn signals just stopped working. I have check the fuse and relay and everything seems fine. The strange thing is that the hazards lights work fine. please help.
Joe
bholmes 06-16-2008 05:42 PM
Maybe the switch is bad, since it would be a different switch than your hazards. Break out the ol' multi-meter and see if you have continuity in that circuit.
Arizona_928 06-16-2008 05:56 PM
when you turn it on does the light in the cluster stay solid? or does it blink?
lyons8821 06-16-2008 06:14 PM
Turn Signal issue
Guys I found out that its in the fuse board itself. When I lift it up and tilt it to the inside to look around the signals start working. So I have either a broken wire, loose connection or a bad fuse board. :o man it seems to never end.
