lyons8821's Avatar
Turn signal
Guys my turn signals just stopped working. I have check the fuse and relay and everything seems fine. The strange thing is that the hazards lights work fine. please help.
Joe
Old 06-16-2008, 05:46 PM
Send a message via AIM to bholmes
Maybe the switch is bad, since it would be a different switch than your hazards. Break out the ol' multi-meter and see if you have continuity in that circuit.
Brian
'86 944 NA
'94 Jeep Cherokee 3" and 31's
'86 Chevy C10 425hp
'98 Dodge Neon (the wife)
Old 06-16-2008, 06:42 PM
Arizona_928's Avatar
when you turn it on does the light in the cluster stay solid? or does it blink?
dolor et pavor
Copyright
Old 06-16-2008, 06:56 PM
lyons8821's Avatar
Turn Signal issue
Guys I found out that its in the fuse board itself. When I lift it up and tilt it to the inside to look around the signals start working. So I have either a broken wire, loose connection or a bad fuse board. man it seems to never end.
Old 06-16-2008, 07:14 PM
