No start 944
Hi everyone, I am new to Porsche, but got a 911 a month ago, so I havent checked much on the 944 side. Now I have aquired a 944 today, and need a little advice. Maybe a good wiring diagram would do, but figured that the experience in this forum will shed some light on my problem. I have an 85 or 86 944 that cranks when you turn the key, but its not getting fuel. Also I noticed that the guages dont come alive either. I thought it was low on gas so put 5 gallons in and it didnt move. The tach doesnt jump up either when its cranking, and oil pressure doesnt move. Also the volts stays under ten. Does anyone think the DME relay isnt turning things on. It does click, and fuses were ok. The car did almost start with a little carb clean in the intake, so spark is ok. Thanks everyone, and I look forward to reading and talking to alot of you soon
Old 06-22-2008, 02:56 PM
I had the exact same problem with mine when I got my 924S. It was the pump. Easy to find and to check. Drain the gas back out (gives you a chance to make sure you aren't mixing good new with bad old at the same time) and use a battery and two wires to test the pump.
Could also be a clog in a fuel line. These things tend to sit before they're sold.
Just another perspective for you to look at. Hope things go well over there.
1978 El Camino 350 4 barrel 3-speed automatic The most expensive Lawn Ornament in my county.
1988 Thunderbird Turbo coupe 5-speed manual 2.3L V4 (The Dirty Bird)
1942 Willis Army Jeep 3-speed manual (you can't get it stuck: I dare you to try!)
1987 924S (My Little Silver Money Eater!) 5-speed manual 2.5L SOHC
Old 06-22-2008, 03:20 PM
I wasnt equiped to do to much checking, but fond it odd that none of the guages lit up. My buddy told me it ran not to long ago, and realize that it could be the pump, but the guages and lights seem to be more of an issue that could fix the no start as well. Car has 93000 miles by the way
Old 06-22-2008, 03:33 PM
Send a message via AIM to bholmes
if your tach doesn't bounce that's usually an indicator that something is bad w/ the reference and speed sensors found on the back of the engine. I'd start there. Check out clarks-garage.com for some useful info for sure. ALso there is a relay to the DME (computor) from the ignition that could be a culprit, especially since the DME relay controls the fuel pump when starting. There is a way to bypass the relay to start the car and see if that's the problem, it should be outlined for you in clarks garage. let us know what you find and we'll go from there.
Brian
'86 944 NA
'94 Jeep Cherokee 3" and 31's
'86 Chevy C10 425hp
'98 Dodge Neon (the wife)
Old 06-22-2008, 07:00 PM
Brian
'86 944 NA
'86 Chevy C10 425hp
Thats all great info, and I appreciate it. Where can I get a wiring diagram for the car. Again I question why I have no guages or lights on the dash. If for some reason I have no power to the cluster, then the tach wont bounce. I think its more likely something with that
Old 06-22-2008, 07:17 PM
Professional Bull5hiter
Outback Porsche's Avatar
Do a search on the web
Jeff
83 944 Guards Red
23 718 GT Silver
Old 06-22-2008, 08:11 PM
http://www.the944.com/ There's some good info on that site too and click on the bottom link on the left hand side and that bad boy should get ya all the info your little heart may desire as far as schematics goes. Good luck.
PS: also do a search on this site and you might get some stuff too.
Brian
'86 944 NA
'86 Chevy C10 425hp
Thumbs up
thanks everyone, I'll keep you posted
Old 06-22-2008, 09:07 PM
Desert Fox's Avatar
wow same thing just happened to my ranger today. I was driving it and went over some railroad tracks, and about 30 feet later it died and wouldnt turn back on.
83 944 Maroon
87 944s parts car (sold)
92 Ranger Lifted
Old 06-22-2008, 10:05 PM
