Desert Fox's Avatar
968 conversion?
Is it possible to convert a 944 engine to a 968 engine by adding mass air sensor, intake manifold, cylinder head, exhaust headers, dual exhaust system from catalyst to tail pipe, engine wire harness and computer/DME from a 968?
Thanks guys, I really don't know much about the 968.
83 944 Maroon
87 944s parts car (sold)
92 Ranger Lifted
Old 07-07-2008, 11:30 PM
different block, the 968 is a 3.0 liter block where the 944 is a 2.5 liter block
___________
1984 944NA, Autothority Chip, Sport Package, Cone Intake, Removed crap, Cat-delete
Old 07-08-2008, 04:42 AM
That Guy
Techno Duck's Avatar
As mentioned the 968 is a 3.0L and also uses a 16v head. If you found a complete 968 engine, they are a direct swap into the 944 chassis. It just requires a few areas of fabrication to work around some things.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 07-08-2008, 06:18 AM
flash968's Avatar
yes - very different animal
i wouldn't say "direct swap" but it has certainly been done - cooling system changes, and adaptations to the drive train are some of the issues to be dealt with
then there are the suspension and brake upgrades necessary to handle the new power and weight
it can be come a long slippery slope, but it can be one heck of a car when it's done too - there is a guy in the bay area who drives one on a regular basis
Old 07-08-2008, 06:58 AM
flash968's Avatar
Old 07-08-2008, 06:59 AM
You'll also need a flywheel from an S2 -- but you can keep the 944na exhaust from downpipe and back by changing the flanges (I'm not sure if the dimensions of a 968 exhaust would even fit down there.)
Joe Chen Current fleet: '93 Amethyst Violet 968 Cab "Lila" (back in the fleet!) ; '92 Cobalt Blue 968 Cab "Minjonet" - Canadian car
'88 Silberossa 951S "Rosy" - garage queen ; Secret project ; '99 Ford Ranger ; '00 Kawi ZX6R
Former cars: '94 Black 968 Cab "Steffi" (totaled) '87 Nautic Blue 944 S3 "Emma" (blown motor) ; '90 White 944S2 ; parts cars
Old 07-08-2008, 07:06 AM
flash968's Avatar
lol - i was hoping you would pop in on this - you definitely have all the details
Old 07-08-2008, 08:13 AM
Quality
phoenix_iii's Avatar
Doubt the trans would like the extra power very much...
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 07-08-2008, 09:30 AM
Schumi's Avatar
There was a guy, not sure if it was on here or rennlist, swap an entire 968 drivetrain into a 924S.
Also there was a guy (don't think it was the same one) do a 3 litre into 924S swap and ran it at some the Grassroots NASA time trials and got 3rd in class I believe.
Edit: it was the Grassroots "Ultimate Track Car Challenge"
Edit #2- Found the page with some great pics: http://www.cardomain.com/ride/2574674
M
Old 07-08-2008, 10:33 AM
Desert Fox's Avatar
ok, thanks guys. I was looking at all those parts that one of my friends had, And I was thinking about the swap, and what it would entail.
hmm. now to find a turbo trans and a 968 engine.
83 944 Maroon
92 Ranger Lifted
Old 07-08-2008, 03:08 PM
flash968's Avatar
lol - why not just find a 968? then you could spend the time you would spend building it driving it instead
Old 07-08-2008, 03:09 PM
Toofah King Bad
Rasta Monsta's Avatar
I love the idea of a 3.0 924S. Great sleeper, fun track car. . .light, aerodynamic. . .
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 07-08-2008, 03:41 PM
Personally, I wouldn't drop in a 968 motor into a perfectly good 944 -- but if you happen to be a situation where you pulled the motor during an overhaul, and found that the motor was completely toast and you needed a replacement, then I'd say you might as well go a little further and take advantage of an upgrade -- especially if you like a good challenge. IMHO, if you have a running 944, it's infinitely easier to sell it and buy a 968.
BTW, as for the parts your friend is selling (I assume the ones listed in the classifieds and on craigslist) -- it seems to me that it's most appropriate for someone who wants to upgrade the setup from an S2.
Didn't the very first Speed Force Racing/Ninemeister supercharger kit for the 968 motor end up in a 3.0 924s track car? I'd love to go that setup one day....
Old 07-08-2008, 04:35 PM
The swap is alot of work. The 968 Engine is more difficult to work on. And the the look on the faces of 928s, 911's , 951's, and S2's getting passed, is pricess.
I love it when guys see me in there mirror and then wonder why I'm passing them. Then later they tell me how good my car sounds as it when by....
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 07-08-2008, 07:45 PM
Desert Fox's Avatar
well the thing is, I have a 944s laying around, that I want to do something with. I have a messed up 83 engine with a bad head. I might just go try and buy a 968 engine and swap em out. just cause im going to put the car in the junkyard if im not gonna do it, and I really don't wanna junk it.
83 944 Maroon
92 Ranger Lifted
Old 07-08-2008, 09:20 PM
Well.. just know what you're in for. We want you to suceed. But I also want you to know what it really takes if you go that route.
I Swapped a 968 into a 924S
The Early 944 would only be able to run a 86 Turbo Tranny without mods or custom braket. ( I think the 86 has ear style) someone correct me if I'm wrong.
968 Engine $3500
Rebuild stuff ~$1000 if you do it yourself
S2 Bell house + Clutch & pressure plate, and flywheel sensor.
Add bigger Radiator.
short Engine mounts or the Clutch slave will infer with Intake MF.
968 DME wire harness.
Adapting the 9 pin Firwall Engine status connector to a 14 pin + hassel.
Fuel feed line is larger and needs to be adapted.
Throttle cable 968.
968 header to pre cat.
Larger exhaust. 2.5-3"
Read my budget on my post. Cause it adds up and you should be ready or don't bother.
These big swaps will rob you bank account faster than you can say Turbo.
There is a racer up in N cal under the user name Lemmings that's also done this.
A company out of Florida has done several of these swaps and I saw one killer 944/968 sell for around 9K on Evil Bay.
Old 07-08-2008, 10:20 PM
Desert Fox's Avatar
Yeah its in an 87, but Id probably need a transmission too. Its probably one of those things Ill get to later, after I get done fixing my 83, and finish the swap.
I appreciate the input guys. I probably would be better off just buying a late turbo, or and actual 968 for that price then.
83 944 Maroon
92 Ranger Lifted
Old 07-08-2008, 10:36 PM
Tam Lin's Avatar
Me too.
I've done the suspension (KW v3), fibre glass bonnet (in the rest-of-car-colour, so as not to look too ricey) , fibre glass sunroof glued in (ditto), Wilwood brakes, recaro apex seats, Fuchs lightweight wheels.
I've bought a complete 944 S2 as a donor car, to take the plastic tank, transmission, motor and wiring loom out of. Had the head off, and the bores look fine. Compression checks out OK, but I'll probably get the valve guides re-done.
Next, the two are going to become one, around October this year.
The way I figured, the main advantage of the added sophistication of the 968 engine is the below-the-line torque, something my 924s will really not need. Very few 968 make anywhere near the peak torque or BHP they are meant to, so there is little top end advantage over an S2 3 Liter. Brakers yards are full of 944 S2 parts, when I need them, whereas 968 bits are and always will be expensive.
924S 1988 KW3 v3, Wilwood brakes, and a diet. Oh and a 3L 16V drivetrain
Old 07-09-2008, 04:05 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
I was waiting till I saw a post to buy a 968!...lol Took 11 posts. Shoot had he asked to convert an NA to a turbo it would have been at the top! Buy a 951. oooops 968!
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 07-09-2008, 04:45 PM
flash968's Avatar
lol - don't get me wrong, i love the idea of a light car with a big motor - i did quite a few V8 conversions into fiats, mgbs, pintos, vegas, and 240Zs (and one silly one in a 944) - just expensive to do, and the payoff isn't that great
maybe i'm just too old now, but the thought of doing something like that, and dealing with the constant headaches of the retrofit, just isn't as attractive as buying a car already done and driving it - i prefer the driving over the building more now, even though it means i have less power than i might
lol - but then again, i am still tinkering and designing new stuff, so maybe i'm not that old yet after all
Old 07-09-2008, 07:05 PM
