-   -   Removing the OPRV (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/420056-removing-oprv.html)
martin944 07-15-2008 11:51 AM
Removing the OPRV
I'm some trouble unbolting the OPRV on my 87 944S. I tried removing the passenger wheel for easier access, but can't seem to break the OPRV loose. Any suggestions?
Thx
bazar01 07-15-2008 12:34 PM
Use a 24mm (if i remember it right) with a 1/2" universal drive and extension extending out to clear the front bumper and a cheater bar. No need to remove the wheel.
martin944 07-15-2008 12:45 PM
i'll give that a shot, thanks man! for such a low torque bolt, it's a b*tch to get out. :-)
Spidey944 07-15-2008 01:46 PM
Pretty sure it's a 17mm. Other than that, just keep trying. The more extensions/swivels you try and use, the let applied torque you will have. Minimize!!
John_AZ 07-15-2008 02:28 PM
Once removed, change both the outside and inside "O" rings on the one piece OPRV.
999-707-144-40-M100 Oil Pressure Relief Valve O-Ring, Inner or Outer, 2 Per Car, 944 (1987-On), Each $2.50.
PP also sells the crush washer needed to prevent oil drips and future knuckle bleeding and bashing. =====N-043-815-3-M131 Oil Pressure Relief Valve outer Sealing Ring, 944 All, Each
Brand: Fischer & Plath $0.75
GL
John_AZ
1988 924s + 1987 924S
djnolan 07-15-2008 03:26 PM
spray some wd40 on it and work it with a wire brush. mine was baked on from the outside and stuck to the block.
Slam 07-16-2008 08:41 AM
I had one so bad I changed the housing because that was easier than getting the OPRV retainer off.
