martin944's Avatar
Removing the OPRV
I'm some trouble unbolting the OPRV on my 87 944S. I tried removing the passenger wheel for easier access, but can't seem to break the OPRV loose. Any suggestions?
Thx
Old 07-15-2008, 11:51 AM
Use a 24mm (if i remember it right) with a 1/2" universal drive and extension extending out to clear the front bumper and a cheater bar. No need to remove the wheel.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 07-15-2008, 12:34 PM
martin944's Avatar
i'll give that a shot, thanks man! for such a low torque bolt, it's a b*tch to get out. :-)
Old 07-15-2008, 12:45 PM
Spidey944's Avatar
Send a message via MSN to Spidey944 Send a message via Yahoo to Spidey944
Pretty sure it's a 17mm. Other than that, just keep trying. The more extensions/swivels you try and use, the let applied torque you will have. Minimize!!
Doug 86 951
BBS, LSD, MBC, Zeitronix stuff, Rennbay stuff, Pelican stuff, Arneworx stuff, and stuff with more stuff.
Old 07-15-2008, 01:46 PM
Proprietoristicly Refined
John_AZ's Avatar
Once removed, change both the outside and inside "O" rings on the one piece OPRV.
999-707-144-40-M100 Oil Pressure Relief Valve O-Ring, Inner or Outer, 2 Per Car, 944 (1987-On), Each $2.50.
PP also sells the crush washer needed to prevent oil drips and future knuckle bleeding and bashing. =====N-043-815-3-M131 Oil Pressure Relief Valve outer Sealing Ring, 944 All, Each
Brand: Fischer & Plath $0.75
GL
John_AZ
1988 924s + 1987 924S
Old 07-15-2008, 02:28 PM
spray some wd40 on it and work it with a wire brush. mine was baked on from the outside and stuck to the block.
Old 07-15-2008, 03:26 PM
Back from Beyond
I had one so bad I changed the housing because that was easier than getting the OPRV retainer off.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 07-16-2008, 08:41 AM
