Architecture & Porsche's
I need a non-seized pass side hatch latching "post"
anyone have one?
My adjusting screw for the phallic member that latches the hatch down on the passenger's side is loose, but the screw is siezed: so I need the little assembly that hex-screws to the underside of the lid. ![]() Mark
Porsche Club Racing National Scrutineer '89 Andial 951 '82 928R '74 911 RSR 3.6 |
AKA J BERK on Rennlist
pretty sure you can get new stainless ones from Rennbay
Joe Current: 2014 Cayenne S Gone but missed: 2003 996 C4S; 1991 944 S2; 1984 944 NA |
You can get the rubber mounting block from the dealer. If I recall it wasn't terribly expensive; I think it cost me like $30 to replace both blocks and the pins on the early car.
-John '94 968 Iris Blue '85.5 944 White - Rally Cross and wrenching practice '84 944 Gemini Grey (gone, but missed...) |
Misunderstood User
Mark,
I just replace my pins. 944online carries a pin set; complete with pins and 'nuts'. My drivers pin was loose; the threads were worn. The nut wasn't much better. Using a metric allen wrench, I removed the rubber assembly from the hatch. The nut is a tee design and it comes out. Replace the nut, put the assembly back on the hatch and screw in the pin. Replaced the other side too. My hatch has never closed better.
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
