Adjustable Proportioning Valve Help
Where can i get the adapters to put a adjustable Proportioning valve ( 1/8 NPT )
to the stock Brake line ( bubble flare ) ? What size are the stock brake fittings ? |
adaptors in brakes systems are a bad idea - i would change the proportioning valve to one that has the ratings you want - porsche makes several - one of these might work:
5/18bar 951 355 305 01 5/33bar 928 355 305 01 5/45bar 964 355 305 00 5/55bar 930 355 305 01 5/60bar 965 355 305 01 |
Not if you want adjustability on a Racecar
it seems to work fine for everybody i know racing these cars - most of them have gone to either the 5/33 (or 5/45 if they really wanted aggressive rear braking) - i am running the 5/33 and am very happy with the balance - fit right into the oem location - no muss no fuss - no real chances of leaks
have you tried porsche motorsport? |
What about if you run Big Reds on the front ?
| All times are GMT -8. The time now is 04:19 PM. |
