Crew Chief
prooutlaw's Avatar
Adjustable Proportioning Valve Help
Where can i get the adapters to put a adjustable Proportioning valve ( 1/8 NPT )
to the stock Brake line ( bubble flare ) ?
What size are the stock brake fittings ?
Herbert B.
GruppeB #093
Carolinas Region PCA Member
National PCA Driving Instructor
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'83 930S Slantnose (13000 miles)
'86 951 Prototype Testcar built in '84 (56000 miles) Serial #00014
'86 951
'87 944
"Life is short , drive Fast"
Old 07-23-2008, 08:14 AM
flash968's Avatar
adaptors in brakes systems are a bad idea - i would change the proportioning valve to one that has the ratings you want - porsche makes several - one of these might work:
5/18bar 951 355 305 01
5/33bar 928 355 305 01
5/45bar 964 355 305 00
5/55bar 930 355 305 01
5/60bar 965 355 305 01
Old 07-23-2008, 10:16 AM
Crew Chief
prooutlaw's Avatar
Not if you want adjustability on a Racecar
Herbert B.
GruppeB #093
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'86 951
'87 944
Old 07-24-2008, 01:35 PM
flash968's Avatar
it seems to work fine for everybody i know racing these cars - most of them have gone to either the 5/33 (or 5/45 if they really wanted aggressive rear braking) - i am running the 5/33 and am very happy with the balance - fit right into the oem location - no muss no fuss - no real chances of leaks
have you tried porsche motorsport?
Old 07-24-2008, 02:33 PM
Crew Chief
prooutlaw's Avatar
What about if you run Big Reds on the front ?
Herbert B.
GruppeB #093
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'86 951
'87 944
Old 07-30-2008, 06:11 AM
