Mountain Road Maniac
ColoradoSteve's Avatar
Noise in Rear Returns!
About a month ago, I noticed a sound coming from the rear. It sounds like a helicopter rotor and increases in intervals as the car accelerates. Kind of a wump, wump, wump sound. Anyway, one of the boots on the cv was torn and I figured that had to be the problem. I decided to have both half-shafts rebuilt and just reinstalled them. Well guess what? The noise is still there! Wheel bearings seem to be fine and I just got new tires so I am stumped. I guess they could've screwed up the rebuild on one of the half-shafts, I dunno. Any Ideas?
'83 944
'87 951- SOLD!
Old 08-17-2008, 09:20 AM
Straight line wump, wump, wump can also be a bad tire
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 08-17-2008, 05:16 PM
Back from Beyond
^+1. What tires are you running? I had BFGoodrich TAs at one time and they made a helluva racket.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 08-17-2008, 05:17 PM
The sound was there with the old tires ( Dunlops ) and I bought new tires ( Firehawks). Sound is still there. Really weird. I'm thinking that one of the cv axles that I just waited a month for is still bad. Maybe wheel bearings but there is no play in the wheels. Here's what I did. I put the rear wheels up on jack stands and started the motor. Put it in gear , the wheels turned and it was making the noise. Then I removed the right cv axle. I started the engine and put it in 2nd gear . No noise. Is that an accurate test? I hate to wait another month to get the stupid thing rebuilt again and I don't know for sure that's what the problem isHere's another thing; some idiot stripped out the fill plug on the transmission ( I know, should've checked that a year ago) but now I've got to get it out to change the gear oil. Any ideas on how to do that?
'83 944
'87 951- SOLD!
Old 08-17-2008, 06:41 PM
In the Fires of Hell.....
kdjones2000's Avatar
My vote is wheel bearings, even if you think they are good.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 08-17-2008, 10:27 PM
Jeff A.
Send a message via Skype™ to jbaeng
+ on the bearings. does the wump-wump change if you steer hard side to side or when going around turns? this loads or unloads the bearings (depending on direction you turn) and can verify a bearing problem. even if there is no play you could have a chipped bearing ball or race. good luck.
Jeff A.
'88 944
'99 Vanagon
'03 Pilot
Old 08-18-2008, 02:23 PM
