How do I replace backup/reverse switch?
Hello everyone,
The backup switch on my 1985/1 944 has gone bad and I need to replace it.
Has anyone been able to replace the switch without removing the tranny?
The switch is located in a very tight spot and I haven't been able to reach it with any of my tools.
Thanks,
Max H.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 08-18-2008, 09:14 AM
Proprietoristicly Refined
John_AZ's Avatar
Greetings Max,
No need to remove transaxle. Scrub the dirt and oil away so none falls in hole. You may get better view if you jack up rear and take off trans mount if necessary. Any cheap switch similiar to aftermarket will work to get your backup lights working again.
John_AZ
1988 924S + 1987 924S
Old 08-18-2008, 10:17 AM
Thanks John, will try to do it removing the trans mount to get more working space.
Max H.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 08-18-2008, 10:31 AM
Just thinking out loud
mattdavis11's Avatar
You don't have to remove the mount. A deep socket is what I used. IIRC, it's a 27mm. 1 1/8 may have been the ticket though.
91 FJ80
84 Ram Charger (now gone)
Old 08-18-2008, 11:15 AM
