Want my 944 to start up faster
This just bugs me, i have to crank my 87 n/a 4 times. It starts promptly after 4 times every time but i want 1st or 2nd crank like my old 944. What causes this? thanks Josh
1987 944 n/a
Old 09-02-2008, 11:52 PM
Replace your crank sensors.
Good luck, George Beuselinck
Old 09-03-2008, 03:29 AM
thats it? crank and reference sensors are easy, you sure that will speed it up? thanks, Josh
1987 944 n/a
Old 09-03-2008, 10:56 AM
Back from Beyond
Check valve at fuel pump?
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 09-03-2008, 11:03 AM
meister member
speedracing944's Avatar
I vote check valve as well...
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 09-03-2008, 04:17 PM
Proprietoristicly Refined
John_AZ's Avatar
My cars have always taken 2-3 cranks before starting. Basic reason I've read:
The fuel pump in all 944's will only run when the fuel injection computer (DME) gets a speed signal from the engine speed sensor on the back of the flywheel. In other words, the engine must be spinning before the fuel pump is turned on. This is one of the reasons that these cars usually require 2-3 seconds of cranking to start. credit jpk Rennlist.
Before you replace the sensors, clean the connection carefully at the back/top firewall.
If it takes longer, you may have starter issues. Buy a new/rebuilt starter or DIY.
http://forums.vwvortex.com/zerothread?id=2359900&postid=42115781
I agree with the fuel check valve. Just clean it out.
The problem could also be the FPR or fuel damper.
GL
John_AZ
1988 924S + 1987 924S
Old 09-03-2008, 04:43 PM
Eldorado's Avatar
personally? i loved the fact that my 944 started up after the 3rd or 4th crank, after one turn of the key.. made the car sound 'older' and just, to me, gave it a little more appeal..
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 09-03-2008, 07:47 PM
i think its a porsche, and on that note, its a modern sports car, i love it when i turn the key and i have a instant steady idle. When the motor has to crank 3 or 4 times it makes it look tired, and i feel like a poor porsche owner.
thanks for all the suggestions, im going to get on cleaning the connections and the check valve. thanks, Josh
1987 944 n/a
Old 09-03-2008, 10:50 PM
In the Fires of Hell.....
kdjones2000's Avatar
My bet is on the fuel pressure regulator/damper.
I changed the damper when the diaphragm failed, and all of a sudden my car took a while to crank up. Replaced the FPR and it went back to starting on the first try.
Good luck,
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 09-04-2008, 07:42 AM
Eldorado's Avatar
my car started right up after one crank after cleaning my grounds/battery terminals, and replacing the battery.
Kyle
Old 09-04-2008, 05:33 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
Suggestions
1) Test the Battery for CCA
2) clean the starter and batt connectons
3) check speed and ref sensor connections and check gap (0.8 mm per Clarks)
4) check sensors per Clarks.
Mine kicks over on 1 to 2 revs.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 09-04-2008, 10:15 PM
Used & Abused
Have you tried starter fluid down the intake? If it were a fuel delivery problem, it should fire right up. If it were a speed/reference sensor problem, there'd be no difference dumping ether down the intake.
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 09-05-2008, 05:53 PM
gtroth's Avatar
Is it worse starting when car is warm (hot start)?
If so I'd look at FPR (was for me). Check fuel pressure and fuel pressure leakdown.
1995 993C4 guards red
1988 944S alpine white
Old 09-05-2008, 07:05 PM
nope, its exactly the same no matter what temp it is. Its my daily driver, i will run 30 miles, then shut the car off for 5 minutes and go again. I probably start the car 15-20 times everyday, cause im a night owl too. always 4 cranks, ive got today off so im going at all the grounds, and wires. carefully of course.
josh
1987 944 n/a
Old 09-06-2008, 04:59 AM
gtroth's Avatar
Ok. I'd still measure the fuel pressure and fuel pressure leakdown, just to know.
Old 09-06-2008, 10:44 AM
earlr85944's Avatar
I just replaced my crank sensors, went from 3 cranks to starting immediately. I did also regap them, I may have been a hair off.
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 09-06-2008, 12:53 PM
Car wont start all the time
I have a 1989 porsche 944 recently i have been having problems starting the car, the battery is fully charged and there is a full tank of gas. It all starts when I turn the key, it makes the noise like it going to start i guess they call it cranks, but the car just keeps cranking and the engine does not turn on and in the end i end up with a dead battery from trying to start the car. If anyone has a solution please help I would really appreciate it.
Pelican Parts is the Place to Be!!!!
Old 09-07-2008, 07:48 PM
earlr85944's Avatar
best bet is to start anew thread with the "Car wont start all the time" title, alot more people will see it and will help you
83 944....bye bye
Old 09-07-2008, 07:55 PM
PorscheJeff95
fast start
ok, maybe I was lucky....I just cleaned my MAF sensor terminals...soft wire brush and some air...re-plugged it...the car has started 9 days in a row now; morning, noon and night on the first turn of the key. Hey, give it a shot.
Old 09-09-2008, 05:08 PM
fast924S's Avatar
Send a message via AIM to fast924S
WHat should fuel pressure be after sitting over night??/ I noticed that after sitting over night I have 0 fuel pressure, Is this normal or is the check valve bad in my fuel pump??? I havent had any starting issues or performance problems, also no leaks.
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 09-09-2008, 07:26 PM
