-   -   Cluth check hole (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/431187-cluth-check-hole.html)
thekidd 09-18-2008 09:16 PM
Cluth check hole
The other day I was pulling out my starter and noticed (or I think) the clutch check hole. Its about a 1.5'' hole above the starter. There was a big chunk of soft rubber sitting there and some smaller chunks. Is this the clutch check hole or no? It seemed to be a big round rubber gear that was inside. How do you tell if the clutch is good or bad. Maybee I can take pictures of it tommorow for you guys. Thanks.
mikepellegrini 09-18-2008 09:55 PM
If you've got chunks of rubber falling out of the clutch inspection hole, that's not a good thing.
How many miles on your car? And do you know of the clutch was ever done? They haven't sold rubber-centered clutch discs in a while.
I'd guess that if it's come to chunks, your clutch is in its final death throes...
thekidd 09-18-2008 10:23 PM
car ('84) has just under 180k, but the clutch feels fine. Not as good as my 924S clutch, which I was told it was new, and a little better than my old 944, PO owner drove about 5k and tracked once in a while.
speedracing944 09-19-2008 05:50 AM
I would start socking money away for a clutch job. On the old clutch disks there were 2 wear items.
1) the clutch friction material itself
2) The rubber center which degrades, splits and eventually blows.
Plan on installing a new clutch kit with the spring centered clutch. If you have a shop do it plan on about 20 hours of labor and $550 for parts.
I think there may be a write up in www.clarks-garage.com on how to measure the clutch wear.
Speedy:)
thekidd 10-05-2008 10:21 AM
There is some oil that is coming out from that hole too? Does the clutch look any good?http://forums.pelicanparts.com/uploa...1223227249.jpg
http://forums.pelicanparts.com/uploa...1223227269.jpg
http://forums.pelicanparts.com/uploa...1223227288.jpg
krystar 10-05-2008 08:25 PM
maybe rear main seal is also going.
sorry to be bearer of bad news.
