thekidd's Avatar
Send a message via AIM to thekidd
Cluth check hole
The other day I was pulling out my starter and noticed (or I think) the clutch check hole. Its about a 1.5'' hole above the starter. There was a big chunk of soft rubber sitting there and some smaller chunks. Is this the clutch check hole or no? It seemed to be a big round rubber gear that was inside. How do you tell if the clutch is good or bad. Maybee I can take pictures of it tommorow for you guys. Thanks.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 09-18-2008, 09:16 PM
Custom User Title
mikepellegrini's Avatar
If you've got chunks of rubber falling out of the clutch inspection hole, that's not a good thing.
How many miles on your car? And do you know of the clutch was ever done? They haven't sold rubber-centered clutch discs in a while.
I'd guess that if it's come to chunks, your clutch is in its final death throes...
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 09-18-2008, 09:55 PM
thekidd's Avatar
car ('84) has just under 180k, but the clutch feels fine. Not as good as my 924S clutch, which I was told it was new, and a little better than my old 944, PO owner drove about 5k and tracked once in a while.
Old 09-18-2008, 10:23 PM
meister member
speedracing944's Avatar
I would start socking money away for a clutch job. On the old clutch disks there were 2 wear items.
1) the clutch friction material itself
2) The rubber center which degrades, splits and eventually blows.
Plan on installing a new clutch kit with the spring centered clutch. If you have a shop do it plan on about 20 hours of labor and $550 for parts.
I think there may be a write up in www.clarks-garage.com on how to measure the clutch wear.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 09-19-2008, 05:50 AM
thekidd's Avatar
There is some oil that is coming out from that hole too? Does the clutch look any good?
Old 10-05-2008, 10:21 AM
maybe rear main seal is also going.
sorry to be bearer of bad news.
Old 10-05-2008, 08:25 PM
