meister member
speedracing944's Avatar
Am I crazy for not wanting to reinstall the front & rear timing belt covers?
I am in the process of resealing the balance shafts. I am seriously considering just leaving off the front and rear timing belts covers. This would make maintenance on the belts so much easier.
Any thoughts on this?
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 09-27-2008, 10:36 AM
1984 porsche 944 na
ballysdad's Avatar
You would probably get the chance to do them more often.. Oil, road dirt flying rocks under the car would probably find an easier target with no proection..
Old 09-27-2008, 10:40 AM
944Spec_bound's Avatar
I've considered the same thing. I see it on track cars and ya, it looks more hardcore.
But what's the benefit? A few more minutes to adust/change belts. About 2 lbs weight savings.
What's the downside? Possible bent valves etc from crap flying into them. An open spinning trap to grab you while working on it.
84 Red 944 NA - Das Swurvenwagen - still street legal but it's just a track toy
My Website:
http://www.TrackPics4Less.com
Old 09-27-2008, 11:04 AM
Nobody Special
I leave mine on for no good reasons although I have yet to hear of anyone loosing a belt from debris. If more people would use the belly pans designed for these cars it isn't an issue.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 09-27-2008, 11:19 AM
meister member
I never stick my hands in the front of the motor with it running anyways. I am not concerned with the "cool" look. It would just make doing the belts much much easier. I wonder how dirty the area would get or if it would actually be cleaner because I would be able to wipe it down more often. Usually you can eat off my engine. One area of concern is what if the belts get wet from driving in the rain. Although I don't drive it in the rain often, sometimes it does happen.
Speedy
Old 09-27-2008, 12:17 PM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
I think I'm gonna leave them off on my track car. I will have a custom under-tray and it will only be used on the track. I'm not too worried about debris, but it makes it easier to keep track of oil seepage, belt replacement and checking bolt torque.
I wouldn't do it on a street car.
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 09-27-2008, 12:28 PM
Proprietoristicly Refined
John_AZ's Avatar
You live in the snow belt!!! Just think of the crap you will suck up when you hit the first drift. Did you get too near the acetone today? Some little critter that lives in the shed will make a nest and you will kill the varment. Acid rain will come in contact with the belts and age prematurely. Chunks of cheese will form and the belts will slip. You may say you don't use the car in the rain, but the first frosty morning will settle little ice balls on the belts and you will bend valves.
Hay this is fun .
Porsche says to disconnect the snorkel to the air box to keep water out and now you want to open up the entire front of the belt area? The salt deposits on the roads will get on the belts and ruin the belts. The oil deposits and antifreeze on the roads will get on the belts. Mud from your back field will deposit and grow moss.
Yeah, go for it. This was a joke right?
John_AZ
Old 09-27-2008, 03:02 PM
meister member
No not a joke. The car is NOT driven in the snow. As far as the cheese curds, I don't eat them over the engine
Hmmm killing little critters with my timing belt? I think you just sold me on the idea
Speedy
Old 09-27-2008, 04:22 PM
Dirty little kitty
PorscheKitty's Avatar
Send a message via AIM to PorscheKitty Send a message via Yahoo to PorscheKitty Send a message via Skype™ to PorscheKitty
yes you are crazy
Old 09-28-2008, 04:29 AM
earlr85944's Avatar
not crazy. i run without the front covers, but I change my belt yearly.....
not for someone who is not doing his own mechanical work
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 09-28-2008, 03:15 PM
Back from Beyond
Modify the inner one by cutting a pie-shaped piece out of it where it goes over the crank. There are enough mounting bolts front to back so it's secure when you put everything together. This way you don't have to take the crank sprockets apart to get the covers off and changing water pumps is so much easier.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 09-28-2008, 06:24 PM
Dtchy's Avatar
I don't see the point...If you're using the car often on the street, why take them off? One rock or other small object in there and you're done.
Just put them on and protect your belts. 15 more minutes on your tensioning job isn't gonna kill you.
Horsepower is how fast you hit the wall...Torque is how far you take the wall with you...
1994 BMW 325is M-Technic
1986 Porsche 944 N/A
Old 09-28-2008, 07:59 PM
meister member
thought about doing this. As of now you have to remove each and every roller in order to remove the rear plastic cover. I might just enlarge the holes around each roller or pully so it can just slip off.
Speedy
Old 09-29-2008, 03:41 AM
Back from Beyond
I'd thought of that, too, but two cuts were easier.
All others GONE!
Old 09-29-2008, 08:58 AM
Do it! I run w/o mine and I thank myself for doing it every time I have to trace a leak, check tension, remove belts, or basically do anything at the front of the engine. Belly pan is a great idea and the odds of something managing to make it past the belly pan and take out the timing belt are far to small for me to worry about.
Old 09-30-2008, 11:52 AM
In my opinion, the risks far outweigh the reward.
Old 09-30-2008, 05:16 PM
meister member
I am worried about the roller bearings wearing out quicker due to the exposure to the elements.
Old 09-30-2008, 06:16 PM
