mikeran's Avatar
Very strange downshifting problem
Yesterday my sons car started a very strange problem. I hope I can describe it good enough on here maybe someone knows what is causing it.
The car drives fine, upshifts are smooth and clean no noise no problems at all all the way through all 5 gears.
Downshift from 5 to 4 no problem, 4 to 3 no problem -
Downshift from 3 to 2 causes a strong vibration/Shudder/thumping noise from under the car.
If you accel in 2nd and then decell by totally letting off the gas no problems at all.
A simple visual inspection under the car shows nothing strange.
Any thoughts?
87 944 - Daily Driver - Son took it and now brought it back
Old 10-10-2008, 03:56 AM
front or back of car?
it's prob too early to start guessing but i'm thinking either motor mount or tranny mount
Old 10-10-2008, 05:43 AM
mikeran's Avatar
Sound more middle to front.
Car doesn't vibrate at idle like bad motor mounts.
Is there a way to inspect the trans mount?
Also if it was mounts wouldn't it do this in all gears? Why only downsifting to 2nd?
Old 10-10-2008, 05:52 AM
rickharrison's Avatar
check the nuts on the axles/cv joints?
3-2 have a lot of torque..perhaps some are loose?
try rev-matching to see if that cures it.
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 10-10-2008, 05:55 AM
flash968's Avatar
probably clutch chatter - the disk is skipping over the flywheel - this is due to one of a couple of different things
it can happen with a flywheel that is too light
it can happen with a DMF that is failing
it can happen if you have deposits on the clutch disk or it is glazed - this is similar to brakes, where you would get vibration in the steering wheel, and is often misdiagnosed as warped rotors
it can happen if the clutch disk is missing pieces
it can happen if you have a rubber center clutch disk that is failing
the reason this only happens going from third to second is that it is the largest gear spacing where you downshift while you are moving at a good speed, and the point where the most torque is being transitioned - the engine and transmission are having the biggest speed difference to overcome
quick test - on a 3-2 downshift, get the car to a speed where you know it happens - then, step on the clutch and while between gears, blip the throttle and rev the engine up to the point you would be at after the downshift - then quickly downshift and release the clutch smoothly - make sure the rpms don't fall before you release the clutch - this will take some good timing - this is called gear matching - we do this on the track - if this eliminates or dramatically decreases the chatter, you have found your problem
Old 10-10-2008, 06:00 AM
mikeran's Avatar
I will try that later, and report back
I am assuming if that works the car needs a new clutch even though it's strong and not that old?
Old 10-10-2008, 06:23 AM
Proprietoristicly Refined
John_AZ's Avatar
mikeran,
I agree with flash968 on the clutch disc. Take out the starter and look for small 1/4 or bigger chunks of rubber disc. There is an inspection hole but the chunks seem to end up by the starter. My rubber disc went out last year and it happened shifting from 2nd to 3rd.
I saw you have your '86 turbo for sale. Your price on both cars is fair. I hope you reconsider restoring the turbo. PS is cheap to replace. Rebuilt rack, tie rod ends and misc parts about $400. Forget about parting out the cars. It is against your neighborhood CCRs and you will spend months on EBay and your back. My 2 cents.
GL
John_AZ
1988 924S 58K + 1987 924S 112K DD
Old 10-10-2008, 06:41 AM
I had the same symptoms, bad rubber center to my clutch. New clutch, no shudder downshifting. It got to the point where I had to rpm match downshifting into 4th and 3rd, originally it was just dropping into 2nd.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 10-10-2008, 07:19 AM
Toofah King Bad
Rasta Monsta's Avatar
Mikeran, ever get this figured out? My car is doing the exact same thing.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-20-2009, 12:29 PM
Send a message via AIM to Icey1174
Mine did the same thing. Soon there after, the clutch went completely. For some reason it was only as you explain with second gear. As it got worse my second gear would "jump" a lot. A lot of jerking in second when on and off the gas. All other gears were fine.
John
'87 944 N/A (first Porsche)
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
'06 Eddie Bauer Explorer
RIP SoCal
Old 08-20-2009, 12:35 PM
Toofah King Bad
Clutch "went" how? Rubber center failed? My disc is Sachs spring centered.
Old 08-20-2009, 12:37 PM
Not sure exactly what the failure was. I shifted into first at a light one day, went to second and nothing. Went back to second and nothing, went to first, nothing, went to third, nothing. Rolled into a parking lot, tried every gear and nothing. The only warning was the problems with second gear.
I had a shop do the work for me. This was before I found this website. They charged me $1800 for a new clutch and all the good junk that comes with it.
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 08-20-2009, 12:40 PM
Eric
It could also be the TT bearings. Mine did that on 3-2 downshifts, but not every time. Terrible vibrations and a brrrrzzz sound. Found that one of the bearings had fallen apart in the tt.
Eric
Old 08-20-2009, 02:38 PM
Toofah King Bad
Not exactly vibrations, more like the entire drivetrain flopping about like a walrus caught in an electric fence.
Old 08-20-2009, 03:00 PM
I know this sounds strange, but check out the exhaust system and all the hangers. I went through this same issue on a car (nephew's) trying to track down the problem, but never solved it before the car spun a rod bearing and got parted. I read online later somebody with the same issue found an aftermarket exhaust / exhaust hanger problem that solved it. After I read this I realised the car I had been working on had a modified exhaust and was probably missing the center hanger. I figure that second gear downshifting must hit a resonant frequency in the exhaust that starts the vibration going. Maybe try and remove the catback part of the exhaust and see if goes away.
I also bet the vibrations aren't there if you rev match the downshift, correct?
Old 08-21-2009, 04:52 AM
Toofah King Bad
They aren't there while rev matching, but the drivetrain is violently hopping around. I don't think the exhaust has enough mass to cause that.
Old 08-21-2009, 06:58 AM
flash968's Avatar
sounds like a pretty typical clutch failure issue - severe glazing, cracked or broken friction material, or a cracked or broken rubber center will do this
Old 08-21-2009, 07:16 AM
I know, It doesn't make sense. I know the exact feeling of the shake you are describing. My nephew's car did it with 2 different good clutches, so i know it wasn't that. His CV's all looked good and were cleaned and re-packed and his trans mount looked good as well. We even tried his transmission in my car to eliminate that. I was at a loss untill the car spun a rod bearing.
Good luck!
Old 08-21-2009, 07:33 AM
yep, +1 on robm-951. check your exhaust hanger and supports especially the ones close to the torsion tube.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 08-21-2009, 08:18 AM
John_AZ's Avatar
Rasta Monsta recently installed a 951 plastic gas tank and went to a single transaxle mount.
http://www.924board.org/viewtopic.php?t=29582&highlight=plastic+gas+tank
It seems that the shudder developed or worsened since the change.
Tranny Mount Evaluation
OR
Severe Clutch Shudder
If the direction now is on exhaust hangers and supports, maybe this should be addressed first. I have no input on the single transaxle mount.
GL
John_AZ
1988 924S + 1987 924S
Old 08-21-2009, 09:40 AM
