GostRidr's Avatar
speedo odo stopped, now what?
There was a recent post on this topic but it went unresolved. Now I am in the same boat. After having the car up on jacks to work on the cooling system, the speedo and odo stopped working before the next test drive. Weird coincidence?!
I have read many posts on this but none that are definitive in this situation.
I believe that there is no cable involved as this is a late model (91 S2)
I have replaced the sensor in the transmission
I have cleaned the ground next to the sensor
Can anyone answer the following?
How do I test the wire, at the sensor, backwards (I have very limited electrical experience and hope this is a good place to learn some basics)?
Could it be the speedometer/odometer gauge itself? If so, can this be tested and confirmed instead of buying and replacing?
Could this be two problems in one? I read some posts saying it could be the infamous gear AND a speedo problem. However, since I have replaced the sensor I am hoping this is ruled out.
Thanks for any help as always,
peter
1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee"
1987 944S Alpine White, Ice Shark Lights "Desert Ghost"
2015 Charger R/T Road & Track
Old 10-27-2008, 03:50 PM
1984 porsche 944 na
ballysdad's Avatar
any other guages out? check relays
Old 10-27-2008, 05:02 PM
GostRidr's Avatar
No other guages out. Don't suppose there is a relay for just these two?! I will do some switching anyway just to rule it out.
peter
Old 10-28-2008, 11:32 PM
GostRidr's Avatar
It looks like I will be taking out the gauge after all. As I do this, does anyone know how I test the wiring while the gauge is out? I mean, I am sure there is a way to test resistance from the gauge back to the sensor in the transmission but which wire and how?! I have GOT to learn this electricity stuff some day!
Thanks!
peter
Old 11-06-2008, 11:50 AM
One thing you can do that will potentially rule out some causes is attach the new speed sender to a drill, then have someone up front check to see if the speedometer moves. If it does, then you are missing a little gear in the tranny. If it doesn't, you have gauge/wire problems.
1986 944 NA
Old 11-06-2008, 01:31 PM
GostRidr's Avatar
What a great idea! I will do this when I am checking my CV bolts!
peter
Old 11-08-2008, 10:54 AM
