-   -   HG set include?? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/438238-hg-set-include.html)
Arizona_928 10-28-2008 09:30 PM
HG set include??
the valve stems?
many944s 10-29-2008 05:20 AM
Valve seals? Yes.
If it's the Victor Reinz kit, I'm not sure about other manufacturers kits through.
John_AZ 10-29-2008 05:25 AM
Originally Posted by many944s (Post 4268613)
Valve seals? Yes.
many944s,
Question,
Some members use an upgraded valve stem seal like silicon instead of the rubber in Victor Reinz kit. What are your thoughts?
Thanks.
John_AZ
many944s 10-29-2008 10:23 AM
I would say it is personal preference...
IMO the traditional Viton seal holds up a little better under hard driving conditions.
The biggest problem with valve seals is they harden over time, thus not sealing well against the valve stem. A common "failure mode" if you will, is the rubber under the metal sleeve that holds the seal to the valve guide breaks down, and the seal rides up the valve stem, rendering the seal useless.
-Nick
John_AZ 10-29-2008 10:50 AM
Thanks Nick,
I'm not familiar with "Viton". I found a site that helped me understand better.
http://www.westpaminis.com/vitonseals.html
More info:
Viton valve stem seals are made from hi-temperature Flouroviton with Teflon to prolong valve stem life and have a spring on the wiper to maintain a positive seal.
John_AZ
