HG set include??
the valve stems?
dolor et pavor Copyright |
Greasy Member
Valve seals? Yes.
If it's the Victor Reinz kit, I'm not sure about other manufacturers kits through.
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
Proprietoristicly Refined
Greasy Member
I would say it is personal preference...
IMO the traditional Viton seal holds up a little better under hard driving conditions. The biggest problem with valve seals is they harden over time, thus not sealing well against the valve stem. A common "failure mode" if you will, is the rubber under the metal sleeve that holds the seal to the valve guide breaks down, and the seal rides up the valve stem, rendering the seal useless. -Nick
Thanks Nick,
I'm not familiar with "Viton". I found a site that helped me understand better. http://www.westpaminis.com/vitonseals.html More info: Viton valve stem seals are made from hi-temperature Flouroviton with Teflon to prolong valve stem life and have a spring on the wiper to maintain a positive seal. John_AZ Last edited by John_AZ; 10-29-2008 at 11:52 AM.. Reason: More info |
