-   -   Flow rate difference between injectors? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/438515-flow-rate-difference-between-injectors.html)
many944s 10-30-2008 01:55 PM
Anyone know what the flow rates or difference in flow rates is between early 944na and late 944na injectors?
TIA,
Nick
Techno Duck 10-30-2008 02:53 PM
If i remember right the early injectors are 22.5lb/hr's and the later ones are 21.8lb/hr.
However i am not sure if the impedance is the same between the two. Check the resistance across the leads before you swap. They should be low, around 2.5ohms.
petrolhead611 10-31-2008 04:02 AM
What is this garbage #3. How do we get this guy blocked?
Z-man 10-31-2008 06:56 AM
He's banned now, and his spam posts are gone.
-Z-man.
