Greasy Member
many944s's Avatar
Flow rate difference between injectors?
Anyone know what the flow rates or difference in flow rates is between early 944na and late 944na injectors?
TIA,
Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 10-30-2008, 01:55 PM
That Guy
Techno Duck's Avatar
If i remember right the early injectors are 22.5lb/hr's and the later ones are 21.8lb/hr.
However i am not sure if the impedance is the same between the two. Check the resistance across the leads before you swap. They should be low, around 2.5ohms.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-30-2008, 02:53 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
What is this garbage #3. How do we get this guy blocked?
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 10-31-2008, 04:02 AM
Z-man's Avatar
He's banned now, and his spam posts are gone.
-Z-man.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 10-31-2008, 06:56 AM
