Angry No dash lights - different problem?
Hi guys! I've been reading this forum, among many others, trying to solve problems with my 86 944. Problem that I'm currently trying to fix is that I have NO dash lights, clock light, etc... This problem stemmed from the dimmer switch being fried. I tried wiring in new dimmer (had to make my own bullet connectors as the plug was fried) and I got nothing except a hot dimmer switch. Additionally the HVAC fan knob has what looks to be a bulb melted into it. Are these circuits linked. I really only care about the dash lights as my clock has a radio in it.
As of now I just have the bare wires taped off and tucked. I would really just like to bypass the dimmer section all together and just have lights that come on with the headlight switch. I have to do an odometer fix as well soon, so i'm not shy about drilling fabbing things if someone comes up with a good idea. Think I could re-wire the lighting circuit to the light switch?
Old 11-01-2008, 03:25 PM
The dimmer is getting hot for a reason and bypassing it will only mask the problem until it causes further damage. If you see a melted bulb holder in the climate control unit, I would start by unplugging the unit and see if that solves the problem. The climate control unit is easy to remove and then you can just unplug the unit.
'89 NA
Old 11-02-2008, 03:37 AM
