Weird sound from rear
A few weeks ago I spun my car out, ended up curbing it.
****ed up my rims but there seemed to be no real damage beyond that.
I jacked it up and thoroughly inspected the tie rods, the brake lines, wheel bearings, I looked at the cv axle but I didn't really know how to tell if anything was wrong and then put a different set of wheels/tires on it.
Anyhow I had my mechanic friend just briefly look at things, and we drove it around a bit and everything seemed tip top. Weirdly, it wasn't even out of alignment (noticeably).
Fast forward to today, I'm noticing a weird slow "wobbling" sound from the rear (I think) passenger side of the car. The car still drives absolutely perfectly, but at low speeds I can hear a gentle slow thump from the rear. It either goes away or road noise overtakes it as I speed up, I'm not sure which - but I can't really hear it outside of parking lots.
I checked and the tire seems securely mounted, nothing loose. I double checked that the lug nuts were all torqued down. I have taken those lugs nuts off and put them back on probably 10 times now. Is it possible they just aren't torquing down like they used to?
Old 11-07-2008, 07:12 PM
bushing inside the suspention might be trashed..
Old 11-07-2008, 07:21 PM
pontifex4's Avatar
It's almost certain not to be this, but have you tried leaving your door open while slamming the hatch? In mine, both pins don't always latch, especially if I try to close the hatch with the windows and sunroof closed, since the cabin air pressure is too great to allow them both to engage. I get a strange, nearly untraceable noise 'from the back' until I get out and slam it.
Likely not what it is in your case, but worth a shot, anyway.
Charlie
'99 996 C2 6 speed - Arctic Silver
Old 11-10-2008, 08:57 AM
rsrmike's Avatar
It may be a wheel bearing... Time will tell if you've damaged it...
Good luck,
Professional Overcomplicator
Old 11-10-2008, 09:38 AM
flash968's Avatar
i would look carefully at the tire - very possible you goose-egged it or popped a cord
Old 11-10-2008, 10:13 AM
