cam belt tensioning problem on a 84 944
I followed the directions for adj. timing belt. When I set belt to specifications and turn engine to two complete turns clockwise and one and a half teeth counter clockwise,belt is loose on the long run of the belt.Clockwise belt is set at the right specifications.Anybody know how to correct this problem?HK
Old 11-04-2008, 04:30 AM
aj951's Avatar
Which procedure and which tensioning gauge are you using? If you are turning the engine counterclockwise at the crank, the slack should be in the long run. If you are turning the engine counterclockwise at the cam gear, the slack will be on the opposite side of the long run.
A.J.
89 944 Turbo
Guru Chip
Lindsey Boost Enhancer
3bar Reg.
Old 11-04-2008, 05:19 AM
I am turning the engine by the crankshaft and I`M using a krikit gauge.Should there be slack in the long run of the belt,when you counter clockwise the engine?Should I keep trying to adjust the belt to get the slack out?HK
Old 11-04-2008, 07:46 AM
aj951's Avatar
You should take your tension measurement with the slack in the long run of the belt between the cam shaft sprocket and the sprocket on the crank. Turning the engine counterclockwise (1 and 1/2 teeth on the cam sprocket, approx 10 degrees) by rotating the crank will get you there. I have the cricket and the Arnnworx tool and have used them both. I found the cricket difficult to use for setting the cam and balance belt. Just my $.02
Good Luck,
A.J.
89 944 Turbo
Guru Chip
3bar Reg.
Old 11-04-2008, 08:45 AM
Zero10's Avatar
Send a message via ICQ to Zero10
The whole point of the procedure is to get the belt worked into position, properly seated on the gears, then put all the tension on the long run.
Thats why it is 2 turns, then just a hair back. You're doing it right, and if you take all the slack out your belt will whine line crazy, demolish the rollers/tensioners and snap in a rather short time.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 11-04-2008, 09:25 AM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
No whining
A properly tensioned new cam belt will not whine. the new Bal shaft belt tends to whine just a bit. If it howls at you, it it too tight. you want a half twist or so on the longest part of the belt. (I don't use tensioner tools, they confuse me, I go by feel)
the upper tensioner pulley on the Bal belt should just "skim" the belt.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 11-06-2008, 08:42 PM
Thanks guys,you helped me a lot.Harry
Old 11-17-2008, 04:40 AM
