need a little info on front springs
I am calling all suspension guru's for a little help. I need to change my daughters 87' n/a back to stock height, and was wondering if early 85' n/a front springs would fit on a 87' 944 that have Koni adjustable front struts. Thanks in advance
( check out the current ride height)
well, i think the first thing to do is figure out what you have in there now
oem koni adjustables or an aftermarket set? oem would be the M030 and COULD use an entirely different spring diameter than an aftermarket unit so, what springs are in there now? |
I believe the are the yellow aftermarket adjustables, I did not know the came with adjustable as an option.
Will work for parts
Basically you need to know the diameter of the spring. If it large than it's most likely stock and any 944 spring would fit.... might not be the same spring rate though.
If its 2.5" then you would need to get a longer hypercoil spring. I believe M030 springs on tuboS and 968's were an all together different size. My bet is that you have the weltmeister lowering springs. Direct replacement for OEM springs. I have some stock turbo springs laying around too if you want them.
'88 944 240,100 miles -race car '05 Boxster 110,000 - Daily Driver '74 911 Targa - long term project |
Non Compos Mentis
Yeah, I want a little more clearance between the fender well and tire. also to reply to 944 boy how much for the turbo springs and how much would it raise the front end?
