Rockin' NW Arkansas
firefighter7128's Avatar
Send a message via Yahoo to firefighter7128
Looking for tips on better throttle response
Looking for a way to get a better response. at the moment if i let off the gas i get the "jolts". again when i give it gas. any easy ways to fix or better the response?
Matt
1986 Porsche 928 S - Daily Driver
1984 928 S - SOLD, 1986 944 S - SOLD, 1988 944 S - SOLD
Old 11-25-2008, 02:50 PM
Learned by do'n twice
Not exactly sure what you are describing but it sounds like it might be drivetrain backlash. This is often caused by a bad clutch or bad CV joints or loose CV joints. At the very least, crawl underneath to make sure the CV joint bolts are not backing out.
Regarding throttle response, installing the throttle cam and lightweight flywheel should improve throttle response.
jmd_forest
86 944 NA - Brought back from the dead
Old 11-25-2008, 03:44 PM
Rockin' NW Arkansas
Cv
I do know the CV's need replacing.
Matt
Old 11-25-2008, 04:32 PM
Redline Racer
HondaDustR's Avatar
Between worn CV joints and the closed throttle switch being an on-off switch that shuts off the fuel flow at higher rpms, yes that would be the explanation.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 11-25-2008, 07:54 PM
Back from Beyond
Adjust the throttle switch so it never closes. That'll get it.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 11-26-2008, 02:03 PM
Redline Racer
HondaDustR's Avatar
then it'll run rich on decel. which might cause problems.
Old 11-27-2008, 08:54 AM
Back from Beyond
Hmm. Interesting. I made this mod after reading Wilk's website info on the shudder problem. While it did fix the throttle-off lurching, I think the car does run a little rich on decel. Not much of an issue for me, but could be annoying - it's a mod for the early cars, really.
All others GONE!
Old 11-27-2008, 10:27 AM
