Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
turbo rear arm comversion
I'm about to put turbo 86 rear arms on my early 85 car. Will I need to change out the spring plates also?
Thanks!
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 11-27-2008, 05:04 PM
Porscaholic and loving it
Ez-Bone's Avatar
Send a message via AIM to Ez-Bone Send a message via MSN to Ez-Bone Send a message via Yahoo to Ez-Bone Send a message via Skype™ to Ez-Bone
Porsche Crest
I too am curious as to what I would need to do to convert
Old 11-27-2008, 05:56 PM
Pretty sure you will have hub offset/wheel issues unless you switch to late wheel and late hubs 23mm vs 53mm. I don't think a new hub would fit on an older trailing arm. I think there is also difference on the upper spring arm but not sure what. Maybe you could do it with spacer plates and longer hub studs.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 11-27-2008, 09:06 PM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
Not quite, the 86' trailing arms (turbo & NA) are aluminum and early offset. 87+ was when the offset changed.
As far as i can tell you should be able to just bolt on the 86 trailing arm to your 85. the camber adjuster tool is the same for all years.
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 11-27-2008, 09:45 PM
