-   -   Removing cams big problem (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/443630-removing-cams-big-problem.html)
1987944Sick 11-28-2008 05:25 PM
I could only take 7 screws off from the cams,and the rest are striped,i did use the right tools the bolts r just too old and wont come out..i tryed drilling on two of them and using the extraction bit,it broke in there and i cant get it out nor can i drill again because its too hard...:mad: whats are my options,if i have to cut those cam holders in halfe then god damn it i will...and just get some used ones:mad::mad::mad:
1987944Sick 11-28-2008 05:50 PM
thought of another idea,ill try grinding down the bolt as much as can with out getting close to anything else..then just buy what ever i damage used from some one..
mikepellegrini 11-28-2008 06:57 PM
We're talking the cam tower? If so, which bolts? The ones on the outside above the exhaust headders or the ones inside the tower?
If it's outside ones, they're relatively easy - you can weld a nut on the head of the bolt, or you can cut a slot in the bolt and take it off like a flat-head screw.
I saw a guy take one off that way - using a small dentist-style air powered drill with a grinder bit, he cut a slot in the top of the bolt, then used a crow-bar (the flat end) as a screwdriver and broke it loose.
I've also heard of guys pounding a cheap 12-point socket (slightly small) onto the bolt (so it jams on), then taking it off that way.
The bolts inside the cam tower are more problematic. I really am not sure what you could do there - without destroying anything. Pounding a socket on might work.
Make sure you "wake-up" any of those bolts before you attemt to break them loose. The steel bolt threads tend to bond with the aluminum after sitting for years.
From Clark's Manual:
http://www.clarks-garage.com/shop-manual/bolt-01.htm
Zero10 11-28-2008 11:39 PM
Worth mentioning, he has an S, so there is no cam tower since it is 16V
Took us 2 pages to sort that out in his other thread. Apparently he feels the need to start from scratch every time he encounters a new issue and not provide any real information.
mikepellegrini 11-29-2008 06:20 AM
Hmm. I musta missed the other thread. Oh well...
