Will program for food
ghnat's Avatar
Airbag fault codes
I used Clarke's Garage to get my fault codes: 30 and 27
30 - Failure Warning Lamp short circuit, check control lamp??? check wiring harness
27 - Ignition Pill circuit 1 break (drivers airbag) plug to driver's airbag, check, replace...
According to Clarke, fix issue or replace control unit for both. Hmm, anyone have any thoughts? I have had the driver's airbag out and checked the connection. I could put a multi-meter to it and verify connection. If I am to check the wiring harness any suggestions where to start? Also check control lamp? help...
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 12-02-2008, 06:52 PM
the lamp is usually becasue the bulb burned out or the fuse to the instruments burned out cause the light to not work
Old 12-03-2008, 02:42 PM
ghnat's Avatar
Is the lamp the Airbag lamp? If so that is lit so I assume it is another lamp???
Greg Hnat
98 Jeep Cherokee
Old 12-03-2008, 02:45 PM
ghnat's Avatar
Update,
I found one of the faults. The contact unit in the steering wheel.
The yellow plug (2 male connectors) goes to the red plug (2 female connectors). Well, using my trusty Fluke multimeter I see either connector from the male side gives continuity to either on the female side. Looks like I need a new contact unit.
Any one have one for sale?
Greg Hnat
98 Jeep Cherokee
Old 12-05-2008, 09:46 PM
Yep, we have those in stock. Less that half the cost at a dealer. Perfect condition, guaranteed.
Lemme know.
gb
Good luck, George Beuselinck
Old 12-06-2008, 06:31 AM
