944 crank cradle
I'm pretty sure I know the answer to this, but it doesn't hurt to ask. Point blank my engine block is cracked and junk. My question is that I can get another stripped block in great condition but the guy lost the crank cradle. Can I use the one from my current engine as long as its ok and the same year? I'm guessing they are milled as one unit and have to be a matching set.
Old 12-13-2008, 11:58 AM
Nobody Special
Your guess is correct, you can't use that block. The girdle is bored for the mains with block and has to be used as a matched unit. A block without a matching girdle makes a nice glass top coffee table though.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 12-13-2008, 02:41 PM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
couldn't he have the assembly line bored to get it back where it needs to be? Obviously this would have to be done by a GOOD machine shop. Probably not worth it unless the price is right on the replacement block (e.g. near free.)
nate
1988 944... and a bunch of other cars
Old 12-14-2008, 06:54 PM
Zero10's Avatar
Send a message via ICQ to Zero10
The cost is not worth it and you would be guaranteed to have to use oversized bearings if it could even be done. If the girdle was close enough you may get lucky, but like the balance shaft covers you should never use anything other than a matched set. Even if the block is free its a bad deal.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 12-14-2008, 11:03 PM
