Help Installing Short 5 th Gear
Anyone with experience installing short 5 th? Are there are special tools/proceedures required? Any tips? Does the transaxle have to come out if the spare tire well has been cut out?
GB
Old 04-21-2009, 09:09 AM
Greasy Member
many944s's Avatar
If you have a cut spare well, you do not need to remove the trans. It would make life easier, but you dont need to.
swapping is fairly straight forward:
-remove rear plug (you will need a new one as the old one is destroyed removing)
-remove bolts holding aluminum tail housing
-remove main shaft bolt (under the now removed rear plug)
-pry off tail housing (be carefull not to drop the "outside" half of the bearing while removing!
-pull "inside" half of bearing
-remove snap ring
-press out the drift pin on the shift fork
-remove exisiting 5th gear grouping
-remove the bolt retaining the 5th speed gear on the secondary shaft
-pull secondary 5th gear
installing the short set is the reverse procedure. Be sure to loctite the shaft bolts upon re-assembly!
Hope it helps!
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 04-21-2009, 01:12 PM
Thanks for the info.
GB
Old 04-21-2009, 04:29 PM
