Weird, scary noise...
So I was driving the 944 the other day when I heard a strange rattling noise, the noise like a bunch of ball bearings flying apart. The noise stopped, and I limped the car home. No noticeable performance loss or problems. Checked underneath the hood and the underside of the car and ... nothing. I can't find anything, but I'm afraid of what may happen if I drive it. Any suggestions on what to look for. The noise seemed to come from under the hood, driver's side....maybe toward the front of the engine. Kinda hard to tell. The only way I can describe the noise was something "flying apart".
'83 NA 66kmi.
Old 12-05-2009, 09:31 PM
Mark944na86's Avatar
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
Take the belt covers off and check all your rollers. Check accessory belts too.
Currently 1990 944 S2, Black on Linen, 17" Turbo Twists
Old 12-06-2009, 03:43 AM
Proprietoristicly Refined
John_AZ's Avatar
Loose crank bolt. Tension should be 150 ft pounds.
If this is the cause, check the pullys for out of round centers.
GL
John_AZ
Old 12-06-2009, 07:25 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Are you missing any cats?
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 12-06-2009, 09:39 AM
