Control Arm Bushings Caster Block clarification?
I want to change out my Caster Blocks (lower control arm bushings). After reading several old posts & looking for parts on here Im a bit confused as to what to get. .....Should I get the updated 968 #951 341 023 01 blocks which say work for 85.5 & up or get the ones that say are for 83-85 .....Im not sure if the 85.5 & up 968 caster blocks will fit on my 83 or are recommended. I see many who say to use updated but none to verify they will work on an 83. Thanks.
1983 944 5 spd, w/ 1984 n/a motor + countless parts from 3 parts cars over the years. Last edited by unclemikeys2001; 02-10-2009 at 02:43 PM.. |
That Guy
Your '83 would have originally came with the stamped steel control arms (black in color). Unless your car was updated to the '85.5-'86 aluminum control arms, the 968 caster blocks will not work.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
thats all I needed to know. The early model ones are less expensive anyways so better for me. Thanks much!!!
1983 944 5 spd, w/ 1984 n/a motor + countless parts from 3 parts cars over the years. |
