-   -   Hole in muffler, need to replace (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/457879-hole-muffler-need-replace.html)
UconnTim97 02-17-2009 12:10 PM
Well, I noticed my muffler developed a golf ball size hole on the drivers side, right behind the tire. I will have to fix this ASAP as my inspection is due soon.
Any one know a garage in the Northeast Philly area that is good for this? I usually go to the dealer(Holbert's), but I was hoping for somewhere closer and cheaper.
Thanks in advance,
Tim
speedracing944 02-17-2009 08:07 PM
buy a used but in good shape one for way less than $100 and slap it on. there are a couple bolts on the front and rear hanger and the 3 holding the pipes together.
Speedy:)
UconnTim97 02-18-2009 05:58 AM
Unfortunately, I have a gravel driveway. Can this be done with out jacking up the car?
bud9344 02-18-2009 07:49 AM
I got mine done by a local mufler shop who does custom work for the Japanese Car. I got two car done mufler and tail pipe and on my Son's car put straight pipe on the cat. for about $280.
My Son likes to make noise while Mine is more melow sound.
http://forums.pelicanparts.com/uploa...1234972086.jpg
http://forums.pelicanparts.com/uploa...1234972161.jpg
exitwound 02-18-2009 08:41 AM
Are there any benefits to attaching either the muffler or the catalytic converter using clamps vs welding them together? I've always used clamps for ease of replacement.
krystar 02-18-2009 08:59 AM
clamps don't seal that well. and the pipes your're going to clamp need to be a good fit and overlap by a good chunk. i think normally they have flared pipes for that purpose.
i had my muffler and a cherry bomb clamped in for a while...but it just keep leaking from moving around. i finally just welded it all in.
