entertaining the idea
UconnTim97's Avatar
Hole in muffler, need to replace
Well, I noticed my muffler developed a golf ball size hole on the drivers side, right behind the tire. I will have to fix this ASAP as my inspection is due soon.
Any one know a garage in the Northeast Philly area that is good for this? I usually go to the dealer(Holbert's), but I was hoping for somewhere closer and cheaper.
Thanks in advance,
Tim
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 02-17-2009, 12:10 PM
meister member
speedracing944's Avatar
buy a used but in good shape one for way less than $100 and slap it on. there are a couple bolts on the front and rear hanger and the 3 holding the pipes together.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 02-17-2009, 08:07 PM
UconnTim97's Avatar
Unfortunately, I have a gravel driveway. Can this be done with out jacking up the car?
Old 02-18-2009, 05:58 AM
Send a message via ICQ to bud9344 Send a message via AIM to bud9344
I got mine done by a local mufler shop who does custom work for the Japanese Car. I got two car done mufler and tail pipe and on my Son's car put straight pipe on the cat. for about $280.
My Son likes to make noise while Mine is more melow sound.
Old 02-18-2009, 07:49 AM
exitwound's Avatar
Are there any benefits to attaching either the muffler or the catalytic converter using clamps vs welding them together? I've always used clamps for ease of replacement.
-Patrick
Black 1986 944
Old 02-18-2009, 08:41 AM
clamps don't seal that well. and the pipes your're going to clamp need to be a good fit and overlap by a good chunk. i think normally they have flared pipes for that purpose.
i had my muffler and a cherry bomb clamped in for a while...but it just keep leaking from moving around. i finally just welded it all in.
Old 02-18-2009, 08:59 AM
