-   -   Easy Way To Remove Rearview Mirror? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/457905-easy-way-remove-rearview-mirror.html)
rabarrer 02-17-2009 02:41 PM
how do i remove the rearview mirror from the windshield?
there doesnt appear to be a set screw like on most other cars
thanks
944Spec_bound 02-17-2009 04:20 PM
I asked the same thing here....
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/399777-rearview-mirror-delete.html?highlight=rearview
jcommin 02-18-2009 07:14 AM
No set screw or fastener. Rubber mallet and wood dowel. Tap upwards.
flash968 02-18-2009 08:29 AM
i am just about to do this so i can install a Homelink mirror with the garage door openers
as i understand it, this process is greatly facilitated by heating up the glue on the mirror mount first (like with a heat gun) - i think i am also going to squirt some carb cleaner in there to soften up the glue - that's what i use to remove glue - it should do a nice job of making this easier (carefully draping everything first of course)
