choinga's Avatar
17mm Transmission Drain Plug Part??
One of my transaxle 17mm hex plugs is about stripped out. Next time I change it, I want to replace the plug but can't find the damn part anywhere. Searching for "transmission drain plug" on pelican only gives me oil plugs.
Anyone know where to find this thing?
Old 02-22-2009, 12:59 PM
Isn't that a metric pipe thread plug? You might not end up with a 17mm hex (it could be a square pipe wrench head on the plug), but can't you find a plug at home depot or lowes or something ...?? Won't have the magnet of course, but in a pinch...
Old 02-22-2009, 01:11 PM
ernie9944's Avatar
automobile atlanta ,1-770 -427-2844 they have them oe ask for george they are not that expensive approx 4.00 $ ***********.com
Old 02-22-2009, 05:01 PM
In the Fires of Hell.....
kdjones2000's Avatar
I have 2 used ones in good shape. Cost of shipping if you want them....
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 02-22-2009, 06:40 PM
why does porsche use the inset giant allens instead of just using a normal hex head plug? .... another one of those "cause that would make too much sense" ?
Old 02-22-2009, 08:46 PM
TNT25169's Avatar
Send a message via AIM to TNT25169
I always ask that question when it comes to some of the bolts for removing the transaxle. Like the ones for the coupler connecting to the torque tube should not have been allen key bolts, or the ones up top on the outer part of the case for later 944s. I sometimes just wonder what they were thinking....
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 02-23-2009, 06:55 AM
