-   -   Engine mounting question (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/458564-engine-mounting-question.html)
amirpc 02-21-2009 10:13 AM
Hey guys,
I've never mounted an engine on an engine stand before.
I just pulled my 951 motor and I've got an engine stand, so my question is simply. How do I combine the two?
My current plan looks like:
1) Pull the bell housing
2) Go get some super long bolts and washers
3) Mount engine to stand and use washers to offset as necessary
Is this plan realistic?
http://forums.pelicanparts.com/uploa...1235239921.jpg
http://forums.pelicanparts.com/uploa...1235240015.jpg
BoxxerSix 02-21-2009 10:23 AM
Yes, pretty much on par. When setting up the stand adapter to the motor itself loosen the arms enough that they move easily, and adjust the positioning of the adapter in relation to the engine so that the main rotating pivot is closer to the center of the motor.
Some new folks tend to position the pivot along the center line of the crankshaft which is fine, but then when they go to rotate the motor so the oil pan is up they have 75% of the weight of the motor leveraging against them. I just try to position motors in stands so the motor spins in the stand in a balanced fashion :)
amirpc 02-21-2009 04:39 PM
So frustrating trying to find bolts! No bolt/fastener store is open on Saturday/Sunday, and most close around 5 on weekdays. When the hell am I supposed to get bolts? haha
Zero10 02-22-2009 12:37 AM
Depending on the length of the tubes on your engine stand, the trick is to use the crossmember mounting bolts to secure the engine to the stand. You gotta take them off to get it out, and you gotta take it off the stand to put it back in, so they are never needed in 2 places at the same time.
If the tubes are really short then you'll have to take the clutch pressure plate off as well, and you may need some washers to space the bolts back, depending on how much of them are threaded.
2Tight 02-22-2009 07:17 AM
As mentioned the X-member bolts are your best option unless you go on-line. I think you will have a very hard time finding the 12mm x 75 (1.5) at any local suppliers. The 12mm I found stocked at various places were all 1.75 pitch. I found out the bellhousing bolts are too short(55) or too long(90) for my new engine stand. Mine is mounted so the mass is fairly centered for a complete long block and it turns much easier.
BoxxerSix 02-22-2009 08:22 AM
Yes finding the right pitch bolts in proper length is difficult in most places. I purchase hardened threaded rods for my stands and use nuts on the backside of the stand adaptor. Beats fussing around finding bolts in the right pitch, then fussing with proper lengths because some holes are blind while others are bore through.
the x member bolts do work though if you're not using them at the moment, but from the looks of your engine stand adaptor I'd say removing the clutch and FW are going to be necessary in your case as the stub arms look way too short on the adaptor to clear those components..
amirpc 02-22-2009 07:41 PM
After I pulled the clutch and bellhousing I was able to mount it using the xover bolts just fine.
Thanks for the help!
http://forums.pelicanparts.com/uploa...1235360460.jpg
krystar 02-22-2009 08:45 PM
do remember the first time u turn it upside down, there's still going to be some fluids inside. get that drip pan underneath :)
and this is the perfect time to clean everything to a whistle.
