944 Stereo Replacement
I have a 1985 Porsche 944 with an earlier style dash, it came with the original two nob radio but now I feel its time to replace the system, but when I went to my local Best Buy to buy my stereo I asked them about the job of replacing the unit and they said it would be very difficult since this stereo was built into the dash...is this true? They said I would have to cut out the old stereo to make the hole to the new one, which i am not very keen on, but they also said depending on the wiring i would have to hard wire the system..... I havnt put a lot of research into the matter but I was wondering if this is the case, I am a student and am buisy and dont have much time to experiment with the stereo would I in fact have to cut it out of the dash? and I have commonly heard that when replacing the rear speakers u cant do it without removing the rear quarter windows?...this sounded somewhat ridiculous but once again I neither have the time to see for myself, just thought I would post this and see what kind of responses I would get with any help or comments, thank you
Old 04-02-2009, 10:49 AM
sl66ICEcuba's Avatar
I replaced the stereo in one of my 924's and my later style 944, in both cars I just pulled the previous radio and the gap was large enough for whatever system you wanted in it. The space was actually large enough for me to fit a flip up navigation unit into both. For speaker wiring, I did not change the speakers but kept the original ones, as for the wring like any aftermarket radio, you have to snip out the old harness connector and connect the new one in. Hope this helps, if you have any other questions, shoot me a PM. Pics upon request if need be.
*1988 944 NA with front end Turbo Conversion*
*1968 400 cubic inch bored and stroked Firebird*
Old 04-02-2009, 11:11 AM
Dont go to best buy. Order the stuff from crutchfield. It will come with the proper wires and tools and you will be able to do it yourself in about 2 hrs with any luck. Simple and you dont get screwed buy BB.
Old 04-02-2009, 11:29 AM
rporzio's Avatar
I had Tweeter replace my whole system including a new head unit, speakers, amplifier and an 8" sub in the spare tire well. They did a fabulous job, had the car all day and I'm very happy with their work.
Of course they are no longer in business now, is that true?
RPorzio
84 944
Old 04-02-2009, 12:02 PM
exitwound's Avatar
All of the in-dash electronics can be bypassed. You just need to locate the switched power source, the ground, and power wires and you're good to go. Any reputable stereo place should be able to do it. Stay away from the best buy type box stores.
-Patrick
Black 1986 944
Old 04-02-2009, 12:15 PM
flash968's Avatar
check your wiring diagram - typically shops like best buy will wire the speakers out of phase on porsches - this is because, unlike japanese and many other cars, STRIPE IS NEGATIVE and SOLID IS POSITIVE
i wasn't aware of this until recently, and i used to be a partner in a car stereo shop (admittedly i had installers doing much of the work, so some things like this escaped me)
Old 04-02-2009, 03:51 PM
1984 porsche 944 na
ballysdad's Avatar
Totally false... This is an easy replacement on the early style dash.. take it to another place and they will probably kiss you it's so easy as long as the back speakers don't need to be replaced then they will talk you out of the whole job..
Old 04-02-2009, 05:43 PM
exitwound's Avatar
Why oh why do you have to take out the rear windows to change the speakers?!
-Patrick
Black 1986 944
Old 04-02-2009, 07:25 PM
I didn't remove the rear windows to change the rear speakers. Simply matter of being careful.
'83 944 N/A
'88 Ford F-150 4WD - Does Everything
'99 300M - Daily Driver, headlights just polished!
'85 34' ITASCA MotorHome, built-in blender baby!
'89 Supra - Black - Future 400hp NA sleeper.
Old 04-02-2009, 08:33 PM
flash968's Avatar
i heard this "rear window" thing before too - a buddy of mine swears they had to do it on one of his cars - not sure what that's about - perhaps it was just to gain access to the panel fabric that was probably glued down?
Old 04-03-2009, 07:13 AM
1984 porsche 944 na
ballysdad's Avatar
You do not have to take out the rear windows you just have to be careful like said before.. If a shop looked up the procedure it would say remove rear windows so they stay away if they can...
Old 04-03-2009, 07:55 AM
thanks for all the posts this is helpful, I looked at the rear speakers and it looks pretty easy to replace the rear speakers without removing the windows, as for the head unit I am planning on doing the job this weekend i was going to buy a pop up screen but the gear lever seems to be to close to the head unit to have a pop up screen but I found a pair of custom subs in boxs designed to fit behind the seats but they were made for a 996....didnt know if they would fit into the 944 but thought it was a good idea, once again thanks for the help, will post with either my success or failure
Old 04-03-2009, 09:44 AM
exitwound's Avatar
How do you get the new speakers in and the old speakers out? There's just not enough room to see what you're doing back there, or to put the new speakers in.
-Patrick
Black 1986 944
Old 04-03-2009, 10:45 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Easy to do. I put a Blaupunkt head in as well as new speakers. Not "blingy" looking at all - very nice look with the early interior and sounds good. The fader knob ever works.
Black Cars Matter
Old 04-03-2009, 11:16 AM
Architect / Car Guy
carlege's Avatar
Send a message via AIM to carlege
ive done 3 stereos and all my speakers amps and such. You can do this its very simple. The hardest part is getting all the wire run if your doing a full system. if not reserve some time during your break and take your time. Disconnect the battery from the car. Make sure the radio antena is attached to the radio this serves as a ground also. No ground no sound. Have fun
As for saving money buy the cheapest thing from crutchfield like speakers they should give you the install guide with it... then buy all your other stuff from cheaper dealers you will save a buch if you do that. Its the same stuff just cheaper make sure the check model numbers
Looking Forward to getting my First "car" Porsche 951
Old 04-03-2009, 12:05 PM
had success in the whole replacement, old head unit slid right out and the new one went right back in, used crutchfield upon recomendation in earlier post (sight and company is amazing!!!! thank you) very excited and happy with the new system, looking forward to tackling the speaker job this coming weekend, thanks to everyone once again with the help and suggestions
Old 04-07-2009, 01:44 PM
In the Fires of Hell.....
kdjones2000's Avatar
Great to hear you are happy
On a (slightly) related note: Who has put one of those pop-up DVD/GPS type of head units into a late model?
I am wondering if the motorized screens only go up 90 degrees, which would not work with the weird angle of the late model systems. Also, would the screen interfere with the shifter?
Thanks, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 04-07-2009, 04:03 PM
vbaron's Avatar
I have the early '85 and replaced the radio recently. The PO had a old Clarion unit and it seemed to be a standard DIN sized unit that I replaced with a Blaupunkt unit. I didn't have to cut it out nor did the dash look to be modified.
Vin
'07 Cayman
'90 911 - SOLD
'05 Boxster (for the wife!)
'85/1 944 - SOLD
Old 04-07-2009, 06:38 PM
