-   -   Broken Hatch Pin - How to Fix (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/466131-broken-hatch-pin-how-fix.html)
ricks911 03-30-2009 09:48 AM
While trying to adjust my rear hatch, I broke one of the rusty pins. The other one is pretty well stuck too so it will most likely break when I try to adjust. I did spray it with WD-40 a few days ago and let it sit, but here I am now:confused:.
Can I remove the bracket and drill out the pin? Or is it easier to get an entire new/used bracket and pin?
Thanks,
Rick
jcommin 03-30-2009 11:05 AM
Bracket easy to remove. Pins are replacable either steel of stainless available. I would try to drill it out. If the threads are bad in the bracket you will need to replace that too.
Gary2397 03-30-2009 12:29 PM
If you have drill handy, the auto parts store sell the drill sets to repair
the broken bolt without destroying the thread hole.
Outback Porsche 03-30-2009 12:35 PM
Be very careful. the bracket (wings) break easily. I ended up getting new brackets and pins.
Cheers
Caponsacchi 03-30-2009 01:09 PM
I just drilled out one of the mount bolts yesterday. The metal is very very easy to drill through. And yeah, watch those wings...
KLR 03-30-2009 06:02 PM
The piece that the pin screws into is actually removable from the piece that bolts to the hatch. I doubt that you'll have much luck drilling out the pins (I didn't), but the female pieces are only about $10 each from Sunset. The pins are similarly inexpensive.
elirentz 03-31-2009 05:10 AM
^+1 Don't waste your time drilling it out. Just remove the block of rubber that the pin screws into and the old pin will pop right out.
