thoen's Avatar
where is the FOGLIGHT Relay?
My foglights don't go on. where is the relay for the foglights located??
Yellow 1983 944. Many alterations, modifications, repairations and aberrations. Great car!!
Old 03-17-2009, 03:44 PM
Not Special
In an early? Should be in the relay block under the dash on the driver's side. Don't have my manual so I can't tell you offhand which one it is...
Current: 1989 Porsche 944 S2 - Baltic Blue/Linen
Former: 1985/1 Porsche 944 - Graphite/Black
Old 03-17-2009, 03:47 PM
PRMN944
It should be above the ECU right side.
Old 03-21-2009, 04:02 PM
PRMN944
Old 03-21-2009, 05:13 PM
Arizona_928's Avatar
it's a loose relay, not on the block?
dolor et pavor
Copyright
Old 03-21-2009, 11:03 PM
thoen's Avatar
thank you gy=uys so MUCH!!!!!!
Old 03-22-2009, 08:28 AM
Just thinking out loud
mattdavis11's Avatar
The 83 not only has loose relays, but relays that are not where the factory says they are. Take for instance the a/c relay and condenser fan relay, which are on the passenger side of the car.
Radio relay and window relay are two others not on the block.
91 FJ80
84 Ram Charger (now gone)
Old 03-22-2009, 08:43 AM
entertaining the idea
UconnTim97's Avatar
Where on the passenger side is the AC relay for the '83?
Thanks in advance.
Tim
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 03-22-2009, 01:09 PM
It's behind the passenger side kick panel, just below the glove box and to the right. Two relays (a/c, and cond. fans) right next to each other, I forget which is which.
91 FJ80
Old 03-22-2009, 02:40 PM
UconnTim97's Avatar
Thanks!
I'll have to take a look later this week.
Old 03-22-2009, 03:12 PM
wow, and I was wondering why the PO removed that kick panel...
dolor et pavor
Copyright
Old 03-22-2009, 08:01 PM
UconnTim97's Avatar
I took the time to change these relays today. What a PITA to get to them. Who decided to put them there?
I lost most of the skin on my knuckles replacing them, but my AC works again! Blows ice cold too.
Thanks again,
Tim
Old 04-04-2009, 04:22 PM
