Question for engine builders -out of round tolerances
Hi all,
Search didn't really help much -- but I am assessing an 86 block for a DIY rebuild. I know I could simply bring the block to the machinist -- and I will before the actual rebuild -- but I would like to learn how to use measurement tools.
So -- I have a theoretical question related to out of round measurement of cylinder bores. Forgive me if the question is dumb -- but I can't figure it out.
When measuring the bore -- how do you actually determine the out of round spec? Is it as simple as taking a measurement in line with the crank and then 90 off of that? Then compare the 2 numbers?
Or do you take many readings and average the readings? The reason I ask is that I have taken 4 measurements at each level (top, below ridge, middle and bottom) 1 in line with crank, 1 at 45deg to crank, 1 at 90deg and and 135deg to crank. Some of the readings show readings over the .020mm limits -- others are within the .010mm to .020mm spec. The average of all the measurements are within spec on 2 cylinders and slightly over spec with the other 2. (I am not sure if the average tells you anything or not -- not a math guy)
I guess the question is this -- how out of round to too out of round? Can 1 point that is out of spec render the whole cylinder out of spec? Has anyone redone a motor with out of round slightly over spec?
Thanks for any insight!
-Dan C.
86 944 NA 2.5
Old 04-01-2009, 08:36 AM
Crickets ...
nobody? I am surprised a bit.
86 944 NA 2.5
Old 04-02-2009, 08:30 AM
flash968's Avatar
almost all slanted engines wear "out of round" - if any dimension is out of spec, you need to correct it to have full compression and avoid further uneven and/or premature wear
sometimes on a slightly out of spec bore you can slap in new rings and run for a while, but it will never run "right" and will not last long
Old 04-02-2009, 08:42 AM
Thanks for the info
Anyone ever run with specs .001mm-.003mm over on taper or out of round specs?
86 944 NA 2.5
Old 04-03-2009, 04:00 PM
I would say that most run .001mm to .003mm out of round or tapered. With dial bore guages, you might catch the .003 but not .001.
drew1
wife has 924 turbo
Old 04-05-2009, 05:58 AM
