-   -   Re-post...alarm issue???HELP!!! (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/466659-re-post-alarm-issue-help.html)
rex00111 04-02-2009 03:42 AM
Ok, so here is the run down....
Bought the car, it had been sitting for three years...
Pertinent information....
1. The horn beeped every time the door opened when I went to trailer it home
2. It started on starter fluid before the work, but it has yet to run on gas
3.Replaced
Fuel Pump
Fuel Filter
Fuel Damper
Fuel Pressure Reg.
All Vac hose
Battery
Ignition coil
Spark plugs
Plug Wires
Dist Cap
Rotor
DME
ALL small fuses
Headlamp relay
J-boot
Belts, some hoses
---- cleaned all fuel lines, jumpered the pump as per clark's, all is well with the pump
so then I...
-----Tested for spark, no spark
-----jumpered the alarm as per clark's, no help
The horn will sound when I go to crank the car, but not every time, and that is a new development, really only happened when I went to try to crank it, and the battery had started to lose power. I have a trickle charger on the battery that I plug it into to keep it charged. I do have a factory alarm, but my ignition key does not fully fit it...however I can turn the keyhole cylinder??? Should it be vertical when armed or horizintal? HELP!!!!
There is no spark that I can see.....have not tested the injectors
What do I do next??? Thank you all for your continued help. What do you think, is this an electrical issue related to the alarm????
Reposted for clarity
rex00111 04-03-2009 06:04 AM
Anyone have any ideas......???? How would I test the dme computer???
kdjones2000 04-03-2009 06:48 AM
The alarm key slot should be vertical if you want your car to start. Horizontal is armed.
I would consider taking the alarm key switch out of the car and looking at it, if it is not acting properly. Look at this post:
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/411435-rekeying-factory-alarm-switch-pics.html?highlight=rekeying+alarm
Good luck, Keith
zedsn 04-03-2009 07:38 AM
Hi, the alarm key will be a seperate key all to itself.
rex00111 04-03-2009 11:36 AM
that figures....you think I should just pull the cylinder and have it re-keyed? That how to link sounds like it would work, but if you guys think it would be easy for a local shop tp re-key the tumbler.....????
zedsn 04-03-2009 12:13 PM
Hi, easiest fix might be to take the cyclinder out and hook the 2 wires together to complete the circut and then put the cylinder back in?
rex00111 04-03-2009 04:05 PM
is this a tied and true fix....my concern would be causing a short of some kind...any advice?
zedsn 04-03-2009 04:12 PM
Hi, it seems to me that all you are doing is completing a circut. I have never had to service my switch but take the inside panel off and go from there.
alantica 04-03-2009 06:14 PM
No-Start 944
Hi rex00111 - Reposted for clarity.
Reference previous threads: Fuel starved, next step? & Fuel pressure question
Cut everything down to the basics.
1) By-pass the alarm. That will stop a no-start condition in the DME computer.
2) If you are not getting a spark and have voltage at the coil, the next step is to swap out that DME. No matter what you do, the DME sends the feed voltage to the coil & if it is not doing so, you will never get a spark.
rex00111 04-04-2009 09:33 AM
took it all apart and cleaned the contacts. I was able to pop off the back instead of having to cut into it....so that helped. The copper connectors were VERY corroded, so I cleaned it up, and put it back. Still have a no-start but am working through it step by step
Thanks to all
