exitwound's Avatar
I have power steering again! Question:
So I was putting on the new (used) pump that I received today and noticed that the fitting that connects the hose from the reservoir didn't match the one I had, and that the hose wouldn't bend to properly feed it. Is this an aftermarket fitting?
One I received
One I had prior
As you can see, the one i had comes out and uses a 90 degree angle to feed the hose, the one I received on the pump did not. I changed them out so there's no problem. I'm just curious why there was a difference.
Ah to have power steering again. Been without it since October.
Installed
-Patrick
Black 1986 944
Old 04-02-2009, 12:46 PM
Proprietoristicly Refined
John_AZ's Avatar
You need the new hose and get a new reservoir tank-the filter clogs>
Of course you could take off your old fitting and use the old hose.
GL
John_AZ
Old 04-02-2009, 12:58 PM
exitwound's Avatar
Wow. The power steering reservoir and the hose have been upgraded? Is the filter in the bottom of the reservoir? I had no idea.
Pelican says that what you're showing me is for 1987-. I have an 86. Have the 86's been upgraded to the new design?
-Patrick
Black 1986 944
Old 04-02-2009, 01:54 PM
John_AZ's Avatar
I show this on the Pelican site:
Home > 924S/944/968 > Suspension > Porsche 924S/944/968 Steering System
Porsche 924S/944/968 Steering System - Page 2
Power Steering Parts
Power Steering Hose
944-347-445-05-M260 Power Steering Hose, Pump to Reservoir, 924S, 944, 944S/S2, 944 Turbo, 968, NOTE: also requires purchase of 999-230-357-02-M260 Hose Fitting for cars through 1989), Each
Brand: OEM [More Info] $40.50
999-230-357-02-M260 Hose Fitting for Power Steering Hose, Each
Brand: OEM [More Info] $6.00
Power Steering Reservoirs And Parts
928-347-015-05-M103 Power Steering Reservoir, Includes Reservoir Cap and O-Ring, 924S/944/968 All (1983-95), Each
Brand: ZF [More Info] $19.75
http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_SUSstr_pg2.htm
Looks like it fits all through '89
The PS reservoir should be changed if it has not new. The filter clogs.
GL
John_AZ
Old 04-02-2009, 04:44 PM
Tags
power steering pump , ps pump , pulley , steering
