exitwound's Avatar
Low idle at start
I've been researching this problem (at least I think it's a problem) for months without coming to any conclusion.
When the engine is cold (doesn't matter what the ambient temperature outside is, 20F or 60F), the car will idle at 400-600rpm and near sputter out, but it's a steady idle, no fluctuations. After the engine runs for a minute or two, the engine begins to level out and idle higher. When the engine is warm, the idle is >1000 and very steady.
I have replaced all the vacuum lines in the car as well as the DME Temperature sensor, the Oxygen sensor. I have adjusted the TPS to proper adjustments. All new hoses all around, including the small ones by the ICV.
At this point, I have the idle set to >1000 because if I set it to the 850-950 as recommended, the car idles when cold at 300-500rpm and WILL stall out.
Any ideas? How does the ICV fit into the idle? I can't seem to find much reading material as to how it actually works.
-Patrick
Black 1986 944
Old 04-05-2009, 11:52 AM
exitwound's Avatar
Took the intake off and worked on the ICV. I applied a 9v current to it, and it shuts promptly and easily, meaning it's working correctly, I'm guessing. All of the hoses were snug, and there's no punctures or leaks as far as I can see. I readjusted the TPS as well, not that it needed it. But I made sure it was all working properly.
-Patrick
Black 1986 944
Old 04-05-2009, 02:26 PM
Was just about to ask the same question.
Common problem. Subscribing.
Old 04-05-2009, 05:47 PM
nightheart's Avatar
Me too. Mine does the same thing, and I replaced most of the same things. No ideas, just hoping someone else has an answer.
This was probably posted from my phone, so please excuse any typos.
Old 04-05-2009, 05:57 PM
strikinglight's Avatar
Same thing here too. Mine also has a weird thing where it will crank over without starting then as soon as I turn the key off and on again it fires right up... To a low idle sometimes. Not sure if the two have anything to do with each other...
Old 04-05-2009, 11:01 PM
Though ours is an early 944, I cleaned and repaired the AFM, especially the idle bypass port. Also cleaned the idle bypass on the throttle body (AAV). Couldn't tell you which one did the most good, as I did them both before putting things back together. Problem is gone, though.
'83 944 N/A
'88 Ford F-150 4WD - Does Everything
'99 300M - Daily Driver, headlights just polished!
'85 34' ITASCA MotorHome, built-in blender baby!
'89 Supra - Black - Future 400hp NA sleeper.
Old 04-07-2009, 08:46 AM
Tags
icv , idle
