Front panel.
How do I remove the nose panel on my 86 NA? I got the 4 screws off the top but what holds it on from the bottom? I see a screw when I open the headlights on the inside of the panel, is this connected?
Old 04-05-2009, 05:24 PM
Removing front header panel?
since you broughtt his up, can you take a picture of the 2 screws that go into the fenders? i took mine out and mixed them up. i need to know which ones to put back there, thanks.
1987 944S
Old 04-05-2009, 06:00 PM
Thanks for the link. I will get a pic up when after I attack it tomorrow. For some reason there seems to be a mess of bondo or something around the screw by the headlight so it could take a bit.
Old 04-05-2009, 07:30 PM
rattlesnakeracing
alantica's Avatar
Porsche Crest Screwed up!
If I remember correctly, there are screws (I think maybe #10 M bolts) on the left & right side, had to take mine off previously to get to the rotor cap. You have to raise the headlights up to put a socket on them, a magnetic socket is a nice tool to have because you have very little room in which to work.
87 Charcoal Metallic 944{Proj} 88 White Pearl 944{Daily Driver}
87 Silver Mazda RX-7{210K no rbld} 87 Charcoal Mazda RX-7 GSL{Proj} 88 Gold Met RX-7{Parts} 89 Midnight Black Mazda RX-7 Conv.{Proj}
87 Intl. Scout II{Proj} 99.5 Nissan Pathfinder LE {Daily Driver}
USAF (Ret) GO Blue! - - RattlesnakeRacing - Don't Tread on Me!
Old 04-05-2009, 11:12 PM
but what do those ones look like? i cant tell which ones go there
1987 944S
Old 04-06-2009, 11:50 AM
