Lean 944
My 944 is lower on the drivers side than the passenger side by about 1/2"-3/4". It does not sound like a lot but it is very obvious when look at the car or sitting in the drivers seat. What could cause this lean:
1.) Struts/Shocks 2.) Springs 3.) ?????
1984 Guards Red Porsche 944 NA 2005 Suzuki Forenza 2005 Suzuki SV650 **SOLD** 2008 Toyota Siena |
Proprietoristicly Refined
Well, I will guess #3.....??????
Reindex the trorsion bars: http://members.rennlist.com/m758/TbarReindex.htm OR in PDF from Clarks http://www.clarks-garage.com/pdf-manual/susp-06.pdf GL John_AZ 1988 924S + 1987 924S |
do you know if it was in an accident? Body mangled/ fram bent? Where in PA? Near Philly here. But I would say #3 also, haha ?????? I hope someone has answer for you soon. Hershey PA swap meet at Hershey Park on April 25, should go.
Steve- If you havent looked, look- www.clarks-garage.com 87 951 red- Maria (current) 84 944 white- Percilla (current DD) 85.5 944 red- Pinta (past) 87 924S red- Nina (past) |
It was is a small accident but it does not appear to have any structural damage. The panel was replaced by a reputable body shop. I will be in Hershey on April 25th, I am from the Harrisburg area, so it is pretty close.
