Nasty S2 Cab Rattle
Hi
Hopefully someone can help!!! I have just been for a run in my S2 cab and it has developed a strange rattle..... The rattle only occurs at 2900rpm in every gear both going up and down the rev range... I am not sure if it is something loose and the resonation is causing it to vibrate at this frequency or if it is something more sinister??? Has anyone experienced anything like this, your help would be appreciated as I wantto sell the car but dont fancy my chances with this strange noise!!! thanks Rob |
i understand that it does it at 2900 in every gear
does it do it with both the clutch engaged and disengaged? does the clutch engagement have any judder or vibration? |
hi
It only does it with the clutch engaged, the clutch doesnt seem to have any judder or vibration. Do you have experience of a sdimilar problem?? |
how high in the rpm range have you gone? My S2 has a nasty metallic vibration at about 2100, 3200 and 4000, I thought it was a loose heat shield (yours may be), but found hat it was a crack in my catalytic convertor, or resonator, whatever that real big thing is before the muffler.
1991 cabriolet (sold) 1989 S2 1988 S 1987 944 n/a (sold) 1987 944 factory yellow (junked )
ok - so, to be clear, when you step on the clutch pedal it goes away? see if it does it sitting still, out of gear, and at the same rpm
the car doesnt do it when revving freely, only when in gear and driving, could it be something loose or could it be cambelt tension?
Sounds like a loose heat shield.
86 951, vitesse afm chips, lindsey exhaust, Tial 46mm, 968 M030 sways, Koni Yellows, and a few other nice upgrades. black on linen |
