Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
For those in KC or Kansas I may need a little help....
I am moving at months end to NE Kansas and noticed they have inspections and my car will not pass as is so I may need a little help or suggestions to get me thru the process relatively unscathed!!
This is assuming I am correct that Kansas has vehicle inspections...?
My issue is the exhaust, to be more specific, no CAT!...So I may need to borrow someones exhaust to pass then reinstall in your car, unless you have a spare lying around, ok that is a bit optimistic huh!!...lol
My best idea thus far is to splice in a AF CAT on my testpipe, reconnect the O2 sensor and give it a whirl.
My other concern is my PP2 chip, will it need to be removed to pass regardless of a stock exhaust or not?
NOW FOR what you can get for the help......I will have a garage for you to do repair when/if needed and I will help you fix what ever is ill.....now I know some of you PCA KC region dudes could use a garage to get some work done....right!?
Any and all help/suggestions or ideas will be absolutely appreciated and you may be the ONE who saves me from having to sell the car!....OK that was a bit desperate but I will give up my home to keep my car on the road!...
Thanks in advance!!!!!!
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 04-17-2009, 07:32 AM
